error on first use
error on first use
Postby rjgjansen » Thu Aug 02, 2012 8:47 pm
I get this error: HELP!
Error
Exception
org.apache.jasper.JasperException
Message
/WEB-INF/jsp/userSettings.jsp (line: 124, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}]
Java version
Sun Microsystems Inc. 1.6.0_32
Operating system
Linux 2.6.32.12
Server
Apache Tomcat/7.0.29
Memory
Used 29 of 63 MB
Stack trace
org.apache.jasper.JasperException: /WEB-INF/jsp/userSettings.jsp (line: 124, column: 4) "${not command.new and not command.admin}" contains invalid expression(s): javax.el.ELException: Failed to parse the expression [${not command.new and not command.admin}]
at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:42)
at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:408)
at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:199)
at org.apache.jasper.compiler.Validator$ValidateVisitor.checkXmlAttributes(Validator.java:1223)
at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:875)
at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1539)
at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2376)
at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2428)
at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:894)
at org.apache.jasper.compiler.Node$Visitor.visit(Node.java:2434)
at org.apache.jasper.compiler.Node$Root.accept(Node.java:475)
at org.apache.jasper.compiler.Validator.validateExDirectives(Validator.java:1795)
at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:217)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:373)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:353)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:340)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:646)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:357)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:690)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:477)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:402)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:329)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
rjgjansen
Re: error on first use
Postby BKKKPewsey » Fri Aug 03, 2012 11:41 am
I do not know if this is still relevant but from the installation documentation
(Please note that Subsonic currently doesn't work with Tomcat 7.)
Checkout viewtopic.php?f=5&t=8701
Not sure if the error you are seeing is related though :?
