How to install Subsonic on Ubuntu
Tutorials, tips and tricks.
thanks for your help but still I can't get through
Postby ferreol » Wed Sep 09, 2009 9:39 pm
Hello and thanks for your kind help .
However it keeps continuing to redirect me to root volder of my virtualhost .
I will try to explain you the steps of my installation .
I download the tar.gz file 3.7 and copy it to /var/subsonic/standalone
then I edit my subsonic.sh like this :
SUBSONIC_HOME=/var/www/subsonic
SUBSONIC_HOST=my.domain.com
SUBSONIC_PORT=80
SUBSONIC_CONTEXT_PATH=/ # note that I have also tried /subsonic
SUBSONIC_MAX_MEMORY=300 # I have changed to increase value
SUBSONIC_PIDFILE=
SUBSONIC_DEFAULT_MUSIC_FOLDER=/var/www/file/sounds
SUBSONIC_DEFAULT_PODCAST_FOLDER=/var/music/Podcast
SUBSONIC_DEFAULT_PLAYLIST_FOLDER=/var/playlists
Then I run the script it works as it write some files and index in /var/www/subsonic
but then localhost redirect me to my home directory ( /var/www/subsonic) root of my virtualhost . (Note that I have also try by pointing the domain name to /var/subsonic & /var/subsonic/standalone
my virtualhost work as the two other servers are fonctionnals , my site is available as my.domain.com works too
My Java packges installed :
sun-java6-jre & jdk , sun-java6-plugin, sun-java6-bin , openjdk6jre
I don't what to do anymore .
I installed it some days ago and register a fake domain maybee this can stop my web app to pop up when I try to reach the configuration and login page ( http://my.domain.com ) ?
thanks in advance for any help .
ferreol
Postby jigsaw » Fri Sep 11, 2009 5:53 am
Hi ferreol
First of you need to set the HOME-variable correctly:
SUBSONIC_HOME=/var/subsonic/standalone
If you want it to be located at /var/www/subsonic you need to move the tar.gz there and untar it at that location.
Does subsonic start fine when you init the subsonic.sh? Does localhost:8080/ send you to subsonic?
jigsaw
Hello still not fixed
Postby ferreol » Sun Sep 13, 2009 2:16 pm
Hey thanks again for your reply .
I did exatly what you said now and I still cannot get the subsonic page when I try to connect to localhost or mydomain.com defined in the subsonic.sh .
Instead of getting the Subsonic page I get an ftp page showing me the content of the Standalone folder in var/www/subsonic/standalone
I cannot understand why .
DO you have any other ideas ?
ferreol
WORKING NOW
Postby ferreol » Sun Sep 13, 2009 2:43 pm
Hey all
It's working now nicely I have reinstalled using the WAR file and the method described at this link :
http://thismightbehelpful.blogspot.com/ ... e-and.html
Thanks again for your help .
One more question now to reach subsonic from my domain I have to type :
http://my-domain.com/subsonic:8180
Isn't it a way to ask subsonic to be reached by http://my-domain.com
Thanks in advance.
ferreol
Re: WORKING NOW
Postby jigsaw » Sun Sep 13, 2009 7:39 pm
ferreol wrote:Isn't it a way to ask subsonic to be reached by http://my-domain.com
Glad to hear you got it up and running.
To do what you ask next just follow the tutorial from organon on Integrating Subsonic into existing Apache Web Space.
jigsaw
Debian init.d script
Postby lavamind » Sun Sep 27, 2009 11:55 pm
Hello, here is my Debian-flavored initscript for Subsonic standalone, based on the other scripts in this thread :
#!/bin/sh
# /etc/init.d/subsonic
# Description: Linux startup-script for Subsonic standalone
[ ! -d /usr/bin ] && exit
PATH="$PATH:/bin:/usr/bin"
export PATH
USER=subsonic
SERVICENAME="Subsonic Media Streamer"
SUBSONIC_HOME="/var/subsonic/"
PIDFILE="$SUBSONIC_HOME/standalone/subsonic.pid"
PROG="$SUBSONIC_HOME/standalone/subsonic.sh"
test -x $PROG || exit 0
# Functions for starting and stopping subsonic
start() {
        if [ $RETVAL = 1 ]; then
            echo "Will cleanup and try to start.."
            rm -f $PIDFILE
        fi
        echo -n "Starting $SERVICENAME "
        # Start subsonic
        start-stop-daemon --start --quiet --pidfile $PIDFILE --chuid $USER --exec $PROG -- --pidfile=$PIDFILE --home=$SUBSONIC_HOME
   RETVAL=$?
        echo
        return $RETVAL
stop() {
        echo -n "Stopping $SERVICENAME "
        start-stop-daemon --stop --quiet --pidfile $PIDFILE
   RETVAL=$?
        rm -f $PIDFILE
        echo
        return $RETVAL
status() {
        if [ -r $PIDFILE ]; then
            check_pid
            if [ $RETVAL = 0 ]; then
                echo -n "$SERVICENAME is running"
            else
                echo -n "Pidfile found, but subsys is dead"
            fi
        else
            echo -n "$SERVICENAME is not running"
        fi
        echo
        return $RETVAL
check_pid() {
        RETVAL=0
            PID=`cat $PIDFILE`
            PS_PID=`ps -u $USER -f | grep $PID | grep subsonic-booter-jar-with-dependencies.jar | awk '{print $2 }'`
            [ ! $PS_PID ] && RETVAL=1
        fi
        return $RETVAL
RETVAL=0
# See how we were called.
case "$1" in
  start)
            status
            [ $RETVAL = 1 ] && start
        else
            start
        fi
  stop)
            stop
        else
            status
        fi
  status)
        status
  restart)
        stop
        start
        echo "Usage: subsonic {start|stop|status|restart}"
        exit 1
esac
exit $RETVAL
As you can see it's missing the init info headers, though...
lavamind
Postby 3R3 » Wed Oct 21, 2009 10:08 pm
is it really the only way to start the "subsonic.sh" via "sudo"? it gives me the creeps, but it also seems to be the only way it works (in ubuntu jaunty), I tried every other way and am actually no linux noob (just an interested layman ^^). I ran it in xp before, and i am wondering why it has to have root privileges.
anyone can enlighten me?
3R3
Postby lavamind » Sat Oct 24, 2009 9:02 pm
3R3 wrote:is it really the only way to start the "subsonic.sh" via "sudo"? it gives me the creeps, but it also seems to be the only way it works (in ubuntu jaunty)
Running any network-facing application like Subsonic with root privileges is a really bad idea. This means that any security flaw in Subsonic could essentially compromise the whole system it's running on.
Hopefully Subsonic doesn't require root privileges to run. It can be run as any user you like. For example, you could create a "subsonic" user and launch the strandalone process as that user. It will work as long as it can write its log files and read its database and any music folder in your collection.
If you have any problems running it with a regular user account, just look at the log files and adjust file permissions accordingly.
lavamind
Postby 3R3 » Mon Nov 23, 2009 7:59 pm
thanks for the heads up, i didnt think of the logs, just thought java/subsonic/jetty somehow requires to be runs as root, because it failed to start otherwise. will change it right now.
another strange thing i noticed is this:
when i link the subsonic.sh startup-script in /var/subsonic to /usr/bin/subsonic with
ln -s /var/subsonic/subsonic.sh /usr/bin/subsonic
it fails to load, if invoked from somewhere else than /var/subsonic although /usr/bin is obviously in the path.
but when i write a script, in which i just call /var/subsonic/subsonic/sh and place it in /usr/bin, i can start subsonic from everywhere via "subsonic".
what am i missing? why does the linking not work, but the script does?
3R3
Postby mapes » Tue Feb 16, 2010 11:36 pm
Those of us running debian lenny might want to look at this command
update-alternatives --config java
This will change the links to sun java instead of the FSF java
mapes
Previous
Return to Tutorials
