How to Install Tomcat on Ubuntu and Enable HTTPS / SSL
Tutorials, tips and tricks.
Postby anitract » Thu Jan 06, 2011 5:56 am
Should the storepass and keypass secretpasswords be the same password, or different?
anitract
Postby seanpkeown » Thu Jan 06, 2011 11:50 pm
anitract wrote:Should the storepass and keypass secretpasswords be the same password, or different?
I've always use the same password for simplicity but a lot of the forums I've read said that some applications require them to be the same.
Hope that helps,
Sean K
seanpkeown
Postby 3R3 » Thu Jan 20, 2011 8:36 pm
Thanks for the great guide.
I found one typo, and although this is not a guide for the faint of heart (due to the topic^^) but having those unsure moments is always bad when setting up something secure ;) (like SSL)
Typo:
In the sixth code-area in the "running tomcat as unprivilegued user"-section reads
sudo chmod -R 775 /usr/local/tomcat
and should probably read
sudo chmod -R 775 /usr/local/tomcat6
Another thing that wasnt clear from your post (though its pretty intuitive because it worked on first try, but what if it didnt?) was the placement of the "security-restraint" block, from the "auto-forwarding port 80 traffic to the SSL-port"-section (optional additions, first section).
Does it have to go inside the [b]<webapp>-tag or outside it?
I tried inside, thinking of the all-enclosing html-tag and it worked. But it would be nice if you stated where in the file, or at least inside or outside what tags the block belongs.
That said, it still a great guide and its easy and straightforward to follow. I myself wasnt so lucky when I attempted to make a guide ;)
greets,
3R3
3R3
Postby seanpkeown » Tue Feb 01, 2011 1:28 am
3R3 wrote:Thanks for the great guide.
I found one typo,
3R3
Hi 3R3,
Thanks for letting me know about the typos. Ooops :D
I'll update to walk through to help others as they read this.
Thanks again,
Sean K
seanpkeown
Postby daveerickson » Fri Mar 25, 2011 12:52 pm
I am loving Subsonic, and have it installed from the .deb on my 64-bit 10.10 machine. My question is why would I want to run Subsonic on Tomcat? What advantage do I get over the standard install? Thanks.
Dave
daveerickson
Postby calvolson » Sun Jun 19, 2011 4:18 am
Just wanted to say thanks for this. It helped out a ton!
calvolson
Previous
Return to Tutorials
Users browsing this forum: No registered users and 355 guests
