How to Change the SSL Key in Subsonic 4.4.beta1
Tutorials, tips and tricks.
turning off ssl -sick of nags
Postby j3tblk » Sat Apr 16, 2011 1:52 am
I spent all day on this. I can get a cert no problem but I can't get startssl to accept the file sourcing from the jar file
the "tomcat" one
I get errors about the encryption strength and this:
* An error has occured processing your private key.
* Please enter only letters and numbers!
* The Pass Phrase must have at least 10 characters and not more than 32!
* Select the "Certificates Wizard" tab and try it again.
Wow, this is silly complicated.
j3tblk
Postby SKinSF » Wed May 04, 2011 3:21 am
I successfully updated the keystore provided with the default subsonic install with a non-self-signed certificate using the following process.
I run linux, on which I use Tiny CA to manage my SSL certificates. Some time ago, I created a self-signed master CA that I only use for signing the CAs I use for signing client and server certificaes.
My first step was to create a certificate request using Tiny CA, which I then signed as a server certificate using one of my signing CAs. In Tiny CA I then selected the key associated with that server certificate and exported the key without its passphrase (PEM/PKCS#12). I also selected the export option to include the certificate in the PEM output file. This step resulted in the creation of the file subsonic-cert_key.pem that contains the subsonic server certificate and key with no passphrase protection.
Next, I converted the PEM file containing the subsonic server certificate and key to PKCS12 format:
openssl pkcs12 -in subsonic-cert_key.pem -export -out subsonic.pkcs12
Note that openssl prompted for a passphrase, which I gave as subsonic.
With the certificate and key in PKCS12 format, I was then able to import them into the java keystore, subsonic.keystore:
keytool -importkeystore -srckeystore subsonic.pkcs12 -destkeystore subsonic.keystore -srcstoretype PKCS12 -srcstorepass subsonic -srcalias 1 -destalias tomcat
I then updated subsonic.keystore in subsonic-booter-jar-with-dependencies.jar:
zip /usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar subsonic.keystore
I then restarted subsonic and tried it out. It worked.
I'm no java wizard, a google search turned up this page, http://tuohela.net/java_keystore_import, which provided me with the clues I needed.
Thank you to Hile for his Java Keystores PEM Import info!
SKinSF
Postby garyjmellor » Tue May 24, 2011 12:42 pm
I wonder if you could give more details on this part:
"...My first step was to create a certificate request using Tiny CA, which I then signed as a server certificate using one of my signing CAs. In Tiny CA I then selected the key associated with that server certificate and exported the key without its passphrase (PEM/PKCS#12). I also selected the export option to include the certificate in the PEM output file. This step resulted in the creation of the file subsonic-cert_key.pem that contains the subsonic server certificate and key with no passphrase protection..."
I cannot get this to work and would really appreciate the assistance.
Thanks.
garyjmellor
Success!
Postby spookybathtub » Tue Apr 24, 2012 10:30 pm
SkinSF's instructions worked for me, with one change. I had to name the alias subsonic instead of tomcat. I suspect this is a recent change, since I'm running Subsonic 4.6. I started with separate .crt and .key files, provided from InCommon. So I just concatenated those two files to make the PEM file pair, before converting to PKCS12.
EDIT: I thought it worked, but I realized it's not completely right. I'm starting a new thread for this, because this thread is titled 4.4.beta1 and I'm using 4.6 now. viewtopic.php?f=2&t=9396
spookybathtub
Previous
Return to Tutorials
Users browsing this forum: No registered users and 273 guests
