how can i log in to my server from a remote computer?
Tutorials, tips and tricks.
Postby sprbc753 » Sat Apr 03, 2010 4:28 pm
So i have a subsonic.org address since i made a donation, yet i still can no access my site remotely...
is there anything else i need to change firewall wise etc? I am running windows 7 and i already switched in my network settings to allow public access to the subsonic service.
please help!
sprbc753
Postby thomasbruce » Fri Apr 09, 2010 7:29 pm
i have donated and got my name.subsonic.org address. can i use that to connect from a remote computer? or du i need to do all this DNS stuff. im used to be using simplify media and orb, and they connect fine from remote computer without all this stuff. hope someone can help me!
thanks
thomas
thomasbruce
Postby sprbc753 » Sun Apr 11, 2010 3:16 am
TommyBrucey...
You need to open up your port on your router, port 80 probably, and allow for UDP...
i cant recall the link i found its in the tutorials though , good luck!
sprbc753
Postby thomasbruce » Sun Apr 11, 2010 7:23 pm
thank you. it works fine now!
thomasbruce
Re: how can i log in to my server from a remote computer?
Postby tnt533 » Sat Aug 27, 2011 5:54 am
I know this is an old thread but I just thought I would add something for anyone coming through and reading. DO NOT USE PORT 80! That is a port specifically used for http communication *a web server / browser usually* and quite a few ISPs are now blocking port 80 for connections not initiated by your IP address because they see that as you running a webserver from home which normally violates the ToS. When setting up Subsonic you should use a port number that isn't a common number, ie, above 1024. Also be warry of any editing of your hosts files. Just do it the right way and forward the port in your router. In 99% of cases you won't have to mess with adding an exception to windows firewall.
If you access your home PC from outside then you really should have a router between your network and your cable/DSL modem for security. Open ports can be a serious security risk.
https://www.grc.com/x/ne.dll?bh0bkyd2
tnt533
Previous
Return to Tutorials
