Setup Subsonic on IIS 7 (Windows Home Server 2011) - ARR 2.5
Tutorials, tips and tricks.
Re: Setup Subsonic on IIS 7 (Windows Home Server 2011) - ARR
Postby Drashna » Tue Dec 31, 2013 3:44 am
To be honest, I found it a lot easier to setup subsonic to be in the directory that you're going to use on the main server. Apache's httpd and nginx may handle url rewriting better in this regard.
And for setting it up this way, using Tomcat is probably the best solution.
Drashna
Postby csobsidian » Mon Apr 25, 2016 6:24 pm
My WHS 2011 is getting a little long in the tooth as they say but I did update my original post for the correct packages to make this setup work with Subsonic 6.0beta1.
csobsidian
Previous
Return to Tutorials
Users browsing this forum: No registered users and 150 guests
