Streaming Video in JWPlayer with Subsonic 3.8 (with FFMpeg)
Tutorials, tips and tricks.
How useful was this Tutorial:
Mohican is God!
13
57%
Mohican is Satan!
3
13%
I don't believe in either...
7
30%
Total votes : 23
Postby GJ51 » Fri Jul 08, 2011 2:13 pm
I've found that the default settings work pretty well for the most part, but then again, I'm not fully aware of your particular installation history and what you have or have not done to SS that may affect performance.
My suggestion would be to start with a comletely clean installation of SS, which would include deletion of the settings directory - C:\Subsonic on a Windows install and usually some sort of \var directory in Linix installs.
There is also the chance that we can pinpoint the problem and fix it if you can give me enough specific information such as the file type(s) that aren't working and the transcoding string that is currently used for that file type.
It's your call as to whcich approach makes more sense to you based on your knowledge of how "clean" you think you SS installation is.
Postby esper » Tue Jul 12, 2011 5:02 am
Here's what I'm getting after I add the Video directory to my library and try to play a movie (mkv file):
[7/12/11 12:59:26 AM EDT] INFO MusicFolderDao Created music folder /media/mars/backup/video
[7/12/11 1:00:44 AM EDT] WARN FFmpegParser Error when parsing metadata in /media/mars/backup/video/video-popcorn/Movies/Lost In Translation/Lost.in.Translation.2003.DVD5.720p.HDDVD.x264-hV.mkv
[7/12/11 1:00:51 AM EDT] INFO PlaylistInputStream Tommy listening to "Lost In Translation/Lost.in.Translation.2003.DVD5.720p.HDDVD.x264-hV.mkv"
[7/12/11 1:00:51 AM EDT] DEBUG TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/media/mars/backup/video/video-popcorn/Movies/Lost In Translation/Lost.in.Translation.2003.DVD5.720p.HDDVD.x264-hV.mkv] [-async] [1] [-b] [1000k] [-s] [480x360] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-]
[7/12/11 1:00:51 AM EDT] WARN TranscodingService Failed to transcode /media/mars/backup/video/video-popcorn/Movies/Lost In Translation/Lost.in.Translation.2003.DVD5.720p.HDDVD.x264-hV.mkv. Using original.
esper
Postby GJ51 » Tue Jul 12, 2011 1:17 pm
What is your transcoding string?
Postby esper » Tue Jul 12, 2011 5:21 pm
where can I find that?
esper
Postby GJ51 » Tue Jul 12, 2011 6:57 pm
Settings - Transcoding
Look for mkv > flv
Postby esper » Wed Jul 13, 2011 1:25 am
looks like all of the " > flv" strings are the same...
mkv > flv:
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
avi > flv:
esper
Postby GJ51 » Wed Jul 13, 2011 1:40 am
Most likely an error in the metadata in your file created when it was originally encoded. In my Video library ob my public site below there are 4 mkv files that play just fine using the
string.
I used AVS video converter to format the video to mkv.
The only other thing I can think of that may be different on my system is that I updated to a newer release of ffmpeg.
EDIT: This may seem like a silly question, but this is an old thread ... you are using the latest version of Subsonic, right? 4.4
Postby esper » Wed Jul 13, 2011 1:56 am
I tried some other AVI/MKV files downloaded (legally) from public sites that play just fine on a friends Subsonic Server (Windows Install) and I still get the same error.
Yes, I am running the latest Subsonic 4.4 beta 1 on my Ubuntu Server
esper
Postby esper » Mon Jul 18, 2011 9:07 pm
anyone else have any input?
esper
Postby esper » Tue Jul 26, 2011 6:12 am
I found this thread:
http://forum.subsonic.org/forum/viewtopic.php?p=20794
And I notice when I try to run /var/subsonic/transcode/ffmpeg
I get the following error:
-bash: /var/subsonic/transcode/ffmpeg: No such file or directory
When I navigate to that directory I see it contains the following:
faad ffmpeg flac lame oggdec oggenc
however these are all 'red' in my terminal and not executable. is this the problem? if so, what should I do?
esper
Postby tgrhp » Tue Jul 26, 2011 6:04 pm
what do u get if you run:
$ ffmpeg -h
not in /var/subsonic/transcode and in /var/subsonic/transcode
also try
$ ls
in /var/subsonic/transcode/ the transcoders should be sky blue [meaning symbolic links]
you might not have the transcoders installed? what os are using?
tgrhp
Postby esper » Tue Jul 26, 2011 8:26 pm
tgrhp wrote:what do u get if you run:
$ ffmpeg -h
also try
$ ls
esper@bubbles:~$ ffmpeg -h
/usr/bin/python: can't find '__main__.py' in '/usr/share/command-not-found'
also, as I said before, when I 'ls' in the transcode/ directory, the transcoders are listed but they are 'red' - so I guess they're not symbolic links?
what does this mean? are my transcoders not installed? if so, how do I install them correctly? I'm running Ubuntu Server
thanks for the help!!
esper
Postby esper » Wed Jul 27, 2011 5:11 am
figured out the problem...my transcoders weren't installed!
needless to say, I'm feeling pretty dumb right now. thanks for the help though everyone
esper
Previous
Return to Tutorials
