Subsonic.war with Jetty instead of Tomcat
Tutorials, tips and tricks.
Postby NoZomIBK » Fri Sep 07, 2012 8:08 pm
When you try to run subsonic with jetty, you will get an error (see this post)
it happens, because jetty has some extra libs tomcat does not have and it comes to a conflict.
you have to remove the file "WEB-INF/lib/standard-1.1.2.jar" out of the .war file with three easy steps on (linux) commandline:
1) extract the files:
jar xvf subsonic.war
2) delete the lib:
rm WEB-INF/lib/standard-1.1.2.jar
3) rebuild the warfile:
jar cvf subsonic.war *
now you can use the subsonic.war with your jetty
NoZomIBK
Return to Tutorials
Users browsing this forum: No registered users and 171 guests
