How To Install Subsonic on FreeNas 8.3.1 release
Tutorials, tips and tricks.
Postby ForSSUx » Tue Apr 02, 2013 8:27 pm
Hi There,
I'm working as a sound engineer in the Belgian army...We have our own communications department.
At the video department we have 5 Avid stations that uses "Library Music" to enhance the viewing experience.
Our "Library Music" publisher mostly visit us once a year to upgrade ( add ) music.
We have several of these fine publisher ...www.sonofind.com..is one Universal is another.
They tend to do of course things a little different.
Anyway enough with the chit chat.
Tech Spec
Old Avid Unity chassis HP 8200xw Motherboard with 8GB ram and 16 disk each 160 GB running a zfs pool
I opted for FreeNas 8.3.1 release. We have over 500k of songs
I have installed subsonic on it from here http://forums.freenas.org/showthread.ph ... nic-Plugin from Joshua Parker thanks for this.
And learned a lot from here http://www.parmeter.net/ben/2011/02/02/ ... tructions/
After running this I quickly learned that although a great program, I needed tag search and here begins the MusicCabinet story
1) Requierments:
a) a jail setup as described here:
http://doc.freenas.org/index.php/Plugins
b) DNS check like the one from google 8.8.8.8
In the main one can do it via the webpage "Horizontal Network tab and in Global Configuration choose nameserver 1 and fill 8.8.8.8 and/or nameserver 2 8.8.4.4
c) a mount point for your media
2) Remove or make the jail
a) create two datasets in your ZFS pool
b) upload the FreeNAS-8.3.1-RELEASE-x64.Plugins_Jail.pbi
c) make sure the plugin service is active
now to be on the safe side ...the web page doesn't always tells the truth.
Go to the shell and type
[root@freenas ~]#
jls
JID IP Address Hostname Path
1 - software /mnt/DGCOM-Music/jail/software
voila the jail is running and has a JID of 1
d) make sure you can search the jail
[root@freenas ~]#
jexec 1 /bin/tcsh
software#
/usr/libexec/locate.updatedb
3) Installing subsonic in the jail.
a) open the jail
[root@freenas ~]#
jls
okay open the jail with:
[root@freenas ~]#
jexec 1 /bin/tcsh
software#
The software# is the name of my jail and may be different for you
b) install dependencies in the jail
I'm not sure about these steps you can try to skip them..
software#
pkg_add -v -r xtrans
software#
pkg_add -v -r xproto
software#
pkg_add -v -r xextproto
software#
pkg_add -v -r javavmwrapper
software#
pkg_add -r -v http://ftp.urc.ac.ru/pub/OS/FreeBSD/packages-7/Latest/lame.tbz
software#
pkg_add -v -r flac
software#
pkg_add -v -r ffmpeg
Difficult to get the packages?
software# pkg_add -rn openjdk7
Fetching ftp://ftp.freebsd.org/pub/FreeBSD/po...t/openjdk7.tbz... Done.
Package dependency xextproto-7.1.1 for ftp://ftp.freebsd.org/pub/FreeBSD/po...t/openjdk7.tbz not found!
etc....
ping 8.8.8.8 result not okay?
ping google.com result not okay ?
if above doesn't work you'll never find the packages..
I had this at my work we have a public part ipadress are in the 10.29.66.xxx this range has ftp
The working server when running needs to be at 10.120.17.xxx this range has no ftp
So I needed to switch between them and forgot to change the Ipadress of the jail ..
Of course the packages weren't found
exit the jail...
exit
do you have a nameserver in your /etc/reolv.conf?
vi /etc/resolv.conf
some keys for vi "esc" "i" "d" "r" i=insert r=replace d=delete alter between them with the esc key
to save "esc" ":wq!" :wq! is entered at the prompt
to quit without saving ":q!"
so change your /etc/resolv.conf and add nameserver 8.8.8.8 or at the prompt you can:
echo nameserver 8.8.8.8 > /etc/resolv.conf the > pipes the output to a file instead of standard to the screen..
You can also use the gui tab network fill nameserver 1 and IPv4 default gateway !!!
You can also copy the files onto the nas with al its dependencies aargh ..look at the -r
The -r let it go to a standard location if you know another place
software#
setenv PACKAGESITE "ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.3-release/All/"
software#
pkg_add -v -r xproto-7.0.22.tbz
or if you downloaded with fillezilla at home place it somwhere in your jail and do
pkg_add -v /media/ xproto-7.0.22.tbz
notice that the -r is not used
c) installing actual subsonic software
download the stand allone version here http://www.subsonic.org/pages/download.jsp and move it to your share, mine is /mnt/DGCOM-Music
software# mkdir /var/subsonic
software# mkdir /var/subsonic/standalone
software# cd /var/subsonic/standalone
software# tar xvzf /mnt/DGCOM-Music/subsonic-x.x-standalone.tar.gz
some of us will have to do a: chmod 777 *.*
d) adapt some variables here and there
software# vi /etc/hosts
change this line 127.0.0.1 localhost localhost.my.domain
to 127.0.0.1 localhost localhost.my.domain software
software# vi /var/subsonic/standalone/subsonic.sh
SUBSONIC_HOME=/var/subsonic
SUBSONIC_HOST=192.168.1.66 #my jail has ip 192.168.1.66 yours?
SUBSONIC_PORT=4040
SUBSONIC_HTTPS_PORT=0
SUBSONIC_CONTEXT_PATH=/
SUBSONIC_MAX_MEMORY=450
SUBSONIC_PIDFILE=
SUBSONIC_DEFAULT_MUSIC_FOLDER=/media
SUBSONIC_DEFAULT_PODCAST_FOLDER=/media
SUBSONIC_DEFAULT_PLAYLIST_FOLDER=/media
where is it:
#if [ -L $0 ] && ([ -e /bin/readlink ] || [ -e /usr/bin/readlink ]); then
#cd $(dirname $(readlink $0))
#fi
for the java
If you'll get a error in the subsonic.sh_log ( software# cd /var/subsonic ) about java then
if [ -e "${JAVA_HOME}" ]
then
JAVA=/usr/local/openjdk7/bin/java
fi
and
software# pkg_add -v -r openjdk7 (this takes some time)
4) test your subsonic
[root@freenas ~]# jexec 1 /bin/tcsh
software# ./subsonic.sh
Started Subsonic [PID 5613, /var/subsonic/subsonic_sh.log]
write down the pid number 5613
software# kill pidnumber of subsonic you'll wrote down otherwise reboot
exit jail
software# exit
5) startup modifications
echo postgresql_enable="YES" > /etc/rc.conf
subsonic startup script somebody?
6) transcoding
I didn't need this so this is a 1/1 copy of http://www.parmeter.net/ben/2011/02/02/ ... tructions/
mkdir /var/subsonic/transcode
cp /usr/local/bin/lame /var/subsonic/transcode/
cp /usr/local/bin/flac /var/subsonic/transcode/
cp /usr/local/bin/ffmpeg /var/subsonic/transcode/
Configure your transcoder settings. In the Subsonic web interface go to “Settings > Transcoding”.
In this example, I’ve set up FLAC to transcode to WAV, then to MP3. On the line reads “flac > mp3″ modify the following:
Step 1 = flac -c -s -d %s
Step 2 = lame -b 192 – -
Kind Regards and thanks for reading
Guy Forssman
ForSSUx
Return to Tutorials
Users browsing this forum: No registered users and 121 guests
