Remove ffmpeg clutter from log files
Tutorials, tips and tricks.
Postby spookybathtub » Wed Mar 05, 2014 4:24 am
I started noticing errors like this in my subsonic.log file when playing certain songs.
[2014-03-04 19:09:37,118] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [swscaler @ 0x1cc44f0] deprecated pixel format used, make sure you did set range correctly
[2014-03-04 19:09:37,125] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [swscaler @ 0x1cc44f0] No accelerated colorspace conversion found from yuv420p to rgb24.
[2014-03-04 19:09:37,127] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mp3 @ 0x1ccf170] Frame rate very high for a muxer not efficiently supporting it.
[2014-03-04 19:09:37,128] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Please consider specifying a lower framerate, a different muxer or -vsync 2
It never really hurt anything, but I don't like cluttered log files, so I tracked down the problem. When ffmpeg encounters a song with album artwork, it processes it as a video track, usually with MJPEG encoding. We can tell ffmpeg to ignore video tracks by adding -vn to the transcode settings, like this:
ffmpeg -i %s -vn -ab %bk -v 0 -f mp3 -
This makes cleaner log files, reduces hard drive access, and might reduce CPU consumption by a microscopic amount. Don't worry about the album artwork, Subsonic processes it separately, so it will still appear in web views. Of course, don't add this to your video transcoder.
spookybathtub
Return to Tutorials
