When you want to login
Tutorials, tips and tricks.
Postby jan3480 » Fri Apr 25, 2014 6:36 pm
Hi
I have bought one year description and I do not have the user and pw.
I have tried user = admin and pw = admin
What do I wrong I have uninstall the server several times and then tried to login with "admin" , but no luck
If you can help me write to my mail please: jan.mexico@hotmail.com
Thanks in avance: Jan
jan3480
Re: When you want to login
Postby PieterB » Mon Apr 28, 2014 1:56 pm
Jan,
See if you can solve your problem (which I do not really understand) by following the install guidelines:
http://www.subsonic.org/pages/documentation.jsp
Hope this helps.
PB
PieterB
Postby PieterB » Mon Apr 28, 2014 2:00 pm
Second thought:
I seem to remember that 'admin' doesn't have an initial password, so try to log in without a password.
PB
PieterB
Postby GJ51 » Mon Apr 28, 2014 3:32 pm
http://www.subsonic.org/pages/installation.jsp
Important! Immediately after installing Subsonic you should change the admin password to secure the server. Point your browser to the Subsonic web page (see URL below), and log in with username admin and password admin. Go to Settings > Users to change password and create new users.
viewtopic.php?f=2&t=8929
If you can't find a solution that works, the easiest thing to do is a COMPLETE uninstall being sure to delete any data directory, i.e. C\Subsonic in Windows platforms as well as using Programs and Features to uninstall the program. I'm not a Linux guy so don't ask me about that. Then redo a clean installation. If you have issues after that, then you probably need to do the same with Java followed by another attempt at a clean Subsonic install.
If that doesn't work, either you or your computer have some issues beyond the scope of a forum solution. :lol:
Return to Tutorials
Users browsing this forum: No registered users and 86 guests
