How to install Subsonic on FreeNAS
Tutorials, tips and tricks.
Postby sindre_mehus » Mon Aug 10, 2009 12:58 pm
Sorry, this happens if the server is not connected to the internet. This bug will be fixed in Subsonic 3.8.
Postby evoss » Tue Feb 09, 2010 6:18 pm
Does this mean that I can install Subsonic in a Zyxel NSA-220 Plus
Greetings Evoss
evoss
Postby kwils09 » Wed Feb 10, 2010 10:59 am
i like it
_________________________________________
Photo to Painting | hermes purses | recycled plastic adirondack chairs
kwils09
subsonic 4.01
Postby japster » Sun Jun 13, 2010 9:04 pm
I only get version 3.6 working on freenas version 4 won't start.
Is this a known problem?
japster
Postby stallmen » Sun Jun 13, 2010 9:31 pm
I couldn't get 4.0 to work either, 3.9 works fine though. The iPhone doesn't seem to care, but the Android app work let you connect because of the older version.
stallmen
Postby japster » Sun Jun 13, 2010 10:11 pm
thanks for the info
i 'll stick with the android 1.2 version(works fine with 3.6) and will try to upgrade to the 3.9 version on freenas
japster
Postby widemind » Mon Jun 21, 2010 6:13 am
I'm trying to install subsonic 4.0.1 on freenas 7.2.
I can't have access to my_ip:4040 after install and my log returns just one line:
'Unable to access jarfile subsonic-booter-jar-with-dependencies.jar'
What's wrong ? or missing ... !
'll try with 3.9.
thx
widemind
War file not found
Postby Ghizmo » Sat Jun 26, 2010 12:14 pm
Hello everyone,
Sorry but nothing append after i've follow all the tutorial...
I have this error message : Error: WAR file not found: /subsonic.war
What can i do ?
Ghizmo
Postby Big_D_271 » Sat Jul 10, 2010 11:48 pm
widemind wrote:Hi,
'll try with 3.9.
thx
I get the same thing trying to install Subsonic 4.0.1 on FreeNAS 0.7.1 ...
Please HELP!
Big_D_271
Postby Talderon » Mon Aug 09, 2010 3:12 am
Big_D_271 wrote:
widemind wrote:Hi,
'll try with 3.9.
thx
Please HELP!
Found the answer here:
http://forum.subsonic.org/forum/viewtopic.php?p=13104
I have FreeNAS 0.7.1 and Subsonic 4.0.1 (build 1524) – May 13, 2010 up and running. Thanks for everyones help!! :D
Talderon
Postby whackly » Wed Sep 01, 2010 2:46 am
*I already posted this in Talderon's How-To. I'm just desperate so I'm posting it here as well.*
I put some time and thought in to this and gave it a 2nd try without being such an idiot. It appeared as if I had navigated the instructions the 2nd time around and all was well. However, after having rebooted the freenas box, I couldn't get to the subsonic web gui. I went straight to the error log and found this:
Error: could not find libjava.so
Error: could not find Java 2 Runtime Environment.
what did i screw up? I'm clueless. If I try any of the package adds again they fail (and it seems to be because they are already installed). If I run them without the "-r" I get the message "package (insert package here) or its older version is already installed"
whackly
Postby stabu » Mon Sep 13, 2010 5:48 pm
How would i upgrade subsonic on freenas?
stabu
Postby JanoLapin » Sun Jan 23, 2011 10:53 pm
I follow this tutorial, but I have this in my error log :
/usr/local/diablo-jre1.6.0/bin/java: 2: Syntax error: "(" unexpected
Subsonic starts but quit immediately...
Have you an idea ?
Thanks...
JanoLapin
Postby indecline » Tue Feb 22, 2011 7:02 pm
i installed a subsonic
but how to update it ?
just update .sh and .war files and reboot?
indecline
running freenas off usb stick
Postby wnaBsd8d » Sun Mar 13, 2011 7:18 am
I understand that this is for a full installation of freenas however would it be possible to install subsonic on freenas embedded system if you somehow extended the image to make use of the whole usb?
For example, i have a 4GB usb stick with freenas embedded installed on it... from my understanding since the image is only 64mb? or whatever size it happenes to be ...that therefore leaves several GBs not being utilised..
would there be some way to increase the size of the image to accomodate the whole drive thereby allowing subsonic to be installed on the usb drive containing the freenas OS?
Thanks in advance
Please feel free to correct me if i have said anything that is wrong :D
wnaBsd8d
Return to Tutorials
