Subsonic Port 80
Tutorials, tips and tricks.
Subsonic Port 80
Postby konkretor » Sun May 10, 2015 9:24 am
When you are googling after this subject you find many informations about Apache and Nginx to setup a Proxy.
On Linux it gives a easy way to do this.
On Ubuntu/Debian, haproxy is supported on many more plattforms
You need following package haproxy http://www.haproxy.org/
sudo apt-get install haproxy
Config is empty with no function
sudo nano /etc/haproxy/haproxy.cfg
Paste this code in to haproxy.cfg
frontend public
    bind *:80
    default_backend www
    backend www
    timeout server 30s
    server www1 127.0.0.1:4040
service haproxy restart
Now subsonic is runnig under port 80
For SSL Support please look here
http://blog.haproxy.com/2012/09/04/howt ... n-haproxy/
Original Post
http://konkretor.blog.de/2015/02/22/sub ... -20123105/
konkretor
Re: Subsonic Port 80
Postby insann » Tue Feb 16, 2016 1:44 am
hello konkretor are you still active here ?
may you tell me how to show mixed content ?
i'm trying to add ssl with haproxy and after adding it i got a problem displaying mixed content , you may have an idea ?
here are some topics :
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=16129
http://forum.subsonic.org/forum/viewtopic.php?f=3&t=16409
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=16370
thanks Insann
insann
Postby konkretor » Fri Oct 21, 2016 3:12 pm
Hello insann,
i will look for you, now i have read some of this thread.
The Answer with Haproxy is here
konkretor
Return to Tutorials
