Installing updates
Tutorials, tips and tricks.
Installing updates
Postby dhsmith77 » Mon Nov 09, 2015 1:35 pm
I struggle with installing your updates.... all the instructions/installation guides cover new installations... I have a setup that works but I get lost when I try to install an update... it would be very helpful if you provided us with a useful guide for installing a new version... right now I am under the impression that my whole current setup will have to be reconstructed from scratch if I install an update... I've got way too much time invested in getting subsonic set the way I like it to go thru all that again... help please
dhsmith77
Re: Installing updates
Postby Gill » Fri Nov 20, 2015 9:10 pm
Did you get any answer on this? I got here because I had the same question. :)
If you run Subsonic on Windows the configuration will remain the same.
Myself have changed from Windows Server to Ubuntu and I am not sure if I need to redo the configuration. Shouldn't be needed but I will not do anything until I'm sure.
/Johan Gill
https://subsonic.gill.nu
Gill
Return to Tutorials
