Using Letsencrypt SSL with Subsonic
Tutorials, tips and tricks.
Postby texxasrulez » Mon Mar 13, 2017 1:25 am
Here is a simple tutorial to use letsencrypt SSL Certs with Subsonic. This is on a Debian Server
cd /etc/letsencrypt/live/<domain_name>
cat privkey.pem > subsonic.crt
cat cert.pem >> subsonic.crt
cat chain.pem >> subsonic.crt
openssl pkcs12 -in subsonic.crt -export -out subsonic.pkcs12
keytool -importkeystore -srckeystore subsonic.pkcs12 -destkeystore subsonic.keystore -srcstoretype PKCS12 -srcalias 1 -destalias subsonic
zip /usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar subsonic.keystore (zip must be installed or use your compression utility of choice)
Restart subsonic
service subsonic restart
Good Luck and I hope this helps
texxasrulez
Re: Using Letsencrypt SSL with Subsonic
Postby gunslingerfry » Sun Oct 08, 2017 11:08 pm
Hey, just wanted to add that keytool complains if your openssl export password is empty. Additionally, subsonic expects your keystore password to be subsonic.
To the questions asked, subsonic for each i.e.:
Enter Export Password: subsonic
Verifying - Enter Export Password: subsonic
Enter destination keystore password: subsonic
Re-enter new password: subsonic
Enter source keystore password: subsonic
gunslingerfry
Postby acroyear » Tue Jan 16, 2018 2:42 am
These worked for me perfectly on the first try, Ubuntu 14.04. Thanks!
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Return to Tutorials
