How to install Subsonic on OpenFiler
Tutorials, tips and tricks.
Which do you prefer: FreeNAS or OpenFiler?
FreeNAS
9
75%
OpenFiler
3
25%
Total votes : 12
Postby mk6032 » Tue Jul 21, 2009 3:15 am
This tutorial will install Subsonic to an OpenFiler box (http://www.openfiler.com/). This was written using OpenFiler 2.3 x86.
SSH to your OpenFiler box as root. It's always a good idea to update all packages first.
conary updateall
Because GCC includes Java-related support, the potential exists for conflicts between the GCC and JDK documentation. To minimize the chance for conflicts, make sure your system has the latest version of GCC installed.
conary update gcc
Next, issue the following command to determine whether you have GCC's Java-specific packages (called gcc-java) installed:
conary query gcc-java
:!: No conflict exists between the GCC and Java documentation provided the command returns the message: gcc-java was not found
Then, install the JDK by issuing the following command as root:
conary update sun-jdk --resolve
However, if your system has gcc-java installed, a conflict exists between the gcc-java:doc and the sun-jdk:doc components, and must be resolved in one of two ways:
* By removing the gcc-java:doc component and then installing sun-jdk:
conary erase gcc-java:doc
* By installing sun-jdk, but excluding the sun-jdk:doc component:
conary update sun-jdk --resolve --exclude-troves sun-jdk:doc
Download Subsonic standalone:
wget http://prdownloads.sourceforge.net/subsonic/subsonic-3.7-standalone.tar.gz
Make a home for Subsonic and extract the tarball into it.
mkdir /var/subsonic && tar -zxvf subsonic-3.7-standalone.tar.gz -C /var/subsonic
Run Subsonic like you would any other script:
./var/subsonic/subsonic.sh
mk6032
Return to Tutorials
