Subsonic and Apache reverse Proxy problem
Tutorials, tips and tricks.
Postby manovel » Fri Oct 01, 2010 9:39 am
I configured my apache server to reverse proxy subsonic as follows:
Apache config:
ProxyPass /subsonic http://localhost:4040/subsonic
ProxyPassReverse /subsonic http://localhost:4040/subsonic
Subsonic config:
CONTEXT_PATH=/subsonic
It is basically working, but I am unable to logout.
IF i press logout, the login form shows, giving in another username and password and you are back logged in with the previous user.
Anyone knows the reason?
manovel
Postby nipar » Sun Nov 14, 2010 6:12 am
You did'nt say if you installed and activated mod_proxy.
Perhaps this might help you:
http://forum.subsonic.org/forum/viewtopic.php?t=4688&highlight=
nipar
Postby Exrace » Sun Nov 14, 2010 12:59 pm
Saved password maybe? :oops:
Exrace
Postby nipar » Mon Nov 15, 2010 7:36 am
ah, you mean the "Remember me" option :) that would do it
nipar
Postby manovel » Fri Dec 17, 2010 8:26 pm
Mod_proxy is active, I'm using that for other things as well, without problems.
remember password was never cheeked!
Other suggestions?
Thank you
manovel
Postby jungsterber » Sat Jul 30, 2011 7:01 pm
in the above config its something wrongI think.
I think manovel means something like this:
because just apache is aware of the folder "/subsonic"
Whatever at last I will leave you a running config:
What does this config do?
Subsonic iss listening on port 8443 (SSL) but I need a connection via Port 443 also but apache is still listening there, so here the mod_proxy magic:
<VirtualHost *:443>
  ServerAdmin webmaster@yourdomain.de
  ProxyVia full
  ProxyPreserveHost on
  <proxy>
    Order deny,allow
    Allow from all
  </proxy>
    ProxyPass / https://localhost:8443/
    RequestHeader set ClientProtocol https
    AllowCONNECT 443
    SSLProxyEngine on
    SSLEngine on
  ServerName music.yourdomain.de
  SSLCertificateFile /etc/ssl/certs/all.yourdomain.de.crt
  SSLCertificateKeyFile /etc/ssl/private/all.yourdomain.de.key
  ErrorLog /var/log/apache2/music.yourdomain.de-error.log
  CustomLog /var/log/apache2/music.yourdomain.de-access.log combined
</VirtualHost>
Ubuntu/Debian Users also be aware about the file
/etc/apache2/mods-available/proxy.conf
especially if you don´t use the proxy permission config from above...
cheers
jungsterber
Return to Tutorials
