Network Shares In SubSonic
Tutorials, tips and tricks.
Postby djsubsonic » Fri Feb 18, 2011 7:04 pm
I would like to share something with you guy's.
I've made a simple Tutorial to use Network Shares in subsonic.
Screenshots Included...
You can download it Here:
.docx Links:
DropBox: http://dl.dropbox.com/u/8551554/Acces%2 ... Guide.docx
YourFileLink: http://www.yourfilelink.com/get.php?fid=608675
Media Fire: http://www.mediafire.com/?873w07s99446s8k
.doc Links:
Dropbox: http://dl.dropbox.com/u/8551554/Acces%2 ... 0Guide.doc
Media Fire: http://www.mediafire.com/?jfdabk0wrgfs7ol
I'm A Dutch Guy And I'm Sorry If My English Is Crep:$ But I Think That You Guys Understand Me.
djsubsonic
Postby underminded000 » Mon Apr 04, 2011 1:24 pm
Thanks for this. Was driving me crazy.
underminded000
Postby knin69 » Thu Jul 28, 2011 2:59 am
djsubsonic - appreciate the tutorial. Followed the steps provided but I'm unable to successfully add a network share to subsonic.
My setup:
-Running Subsonic service on Windows 64-bit Desktop
-I have a MEDIASHARE MINI (by Verbatim) that is attached to my network. This is where I have all of my media and it is basically a mini NAS for external USB devices. I currently have a 1TB Cavalry USB HD attached to it and have an active network share mapped to the windows machine: \\MEDIASHARE_MINI\External Storage\CAVALRY 1TB\
When I attempt to add the share to subsonic, it is not successful (I tried the UNC path above and also 'X:\CAVALRY 1TB\Music' since I have the MEDIASHARE mapped to drive letter 'X' as well). I added the windows log on account to the service and restarted it as you indicated. However, I must note that the MEDIASHARE utilizes different credentials to log in, could this be the problem? How can i get around this?
knin69
What I did...
Postby XaviorPenguin » Tue Aug 02, 2011 7:22 am
Here is what I did...
Running:
Windows 7 Enterprise x86
Subsonic 4.5 Beta 1
FreeNAS 0.72
Win7 and Subsonic are on my Laptop
FreeNAS, obviously on another machine
1. Created new user in Win7 exclusively for network (networksubsonic)
2. Went to Services -> Subsonic -> Right Click on Subsonic and go to Properties -> Log On Tab -> Choose "This Account" -> Entered in Newly created username (networksubsonic) and entered in Password twice -> Apply -> Hit OK on Dialog boxes -> Hit OK in Properties Box -> Restarted Subsonic Service
3. Went to FreeNAS GUI and went to Access -> Users
4. Hit + Sign
5. Created new user (networksubsonic) with same credentials as I made on Win7 and used the following options
- Shell: nologin
- Primary Group: guest
- Leave everything else be
6. Hit Save
7. Hit Apply Changes
8. Went back into Subsonic to go to Settings -> Music Folders
9. Added a New Folder with the following information
- Name: Test (can be whatever you want, this is what I did to test it)
- Folder: \\prinny-baal\storage\Music (whatever your UNC path is)
10. Hit Save
11. Went to Search ->Update search index now
12. Went to About and constantly hit the Refresh Link
Upon doing so, I saw it was taking a bit longer to update my search index, when I did, I saw an increase in the file listing once all said and done.
Now, I did see that locating where the music was at was just a little slow, but not too bad, it was tolerable. Selecting a song took it about 5 seconds to start to buffer and then start to play through Firefox 5 on Windows 7.
I will try to make a video of sorts to explain what I did if it needs to be done.
XaviorPenguin
Postby djsubsonic » Tue Aug 09, 2011 7:53 am
Ì'm Running Subsonic on ubuntu now with the same network shares that it would get from a vritual server 2003.
And a physical Windows 7 Ultimate machine. Over gigabit network. it takes les than a second to load a song.
Even when i'm not home it takes about 1 second to load the first part of a song, so it's realy fast on ubuntu.
djsubsonic
Re: Network Shares In SubSonic
Postby aaamrtn » Sat Aug 10, 2013 5:18 am
how about for Mac users? Your tutorial looks really helpful but I can't figure out the Mac OS equivalent :(
aaamrtn
Postby christheberge » Thu Aug 15, 2013 3:21 am
Same here, re: the MAC - I'm using Time Capsule on my Wifi LAN as a server with no computer running at all, worked fine for 2 days then lost the media folders
christheberge
Return to Tutorials
