How to get subsonic to work on Synology DS1511+ (10/17/2012)
Tutorials, tips and tricks.
Postby gamezonline » Sat Mar 05, 2011 1:32 pm
If you like me and want to manually install subsonic follow the steps below if you want a automatic way try gigon installer
Note: <version> is the version number of the java you downloaded so say if its version 30 replace 30 where u see <version>
Install Java
mkdir /usr/java
cd /usr/java
wget http://javadl.sun.com/webapps/download/AutoDL?BundleId=69465
mv jre-7u<version>-linux-i586.tar.gz* jre-7u<version>-linux-i586.tar.gz
tar -zx -f jre-7u<version>-linux-i586.tar.gz -C /usr/java
know you are done with java, its that simple since we have a intel based nas it can run the standard linux version of java.
Install Subsonic
mkdir /var/subsonic
mkdir /var/subsonic/standalone
cd /var/subsonic/standalone
wget http://superb-dca3.dl.sourceforge.net/project/subsonic/subsonic/4.7/subsonic-4.7-standalone.tar.gz
tar -zx -f subsonic-4.7-standalone.tar.gz -C /var/subsonic/standalone
now this part is kinda tricky because i cant stand the telnet edit client. so what i did make make a tmp share on volume1
cp /var/subsonic/standalone/subsonic.sh /volume1/tmp
now on the windows u browse to that share (/volume1/tmp) opened the subsonic.sh in notepad and change on about line 97
From
JAVA=java
TO
JAVA=/usr/java/jre1.7.0_<version>/bin/java
Note: if the java <version> is less then ten add a 0 before it. example... <version> is 9 so i put 09.
now save the file
cp /volume1/tmp/subsonic.sh /var/subsonic/standalone
chmod 777 /var/subsonic/standalone/subsonic.sh
cat > /usr/syno/etc/rc.d/S99Subsonic.sh
Type the next step in the termanel or copy/paste it, its up to you
#!/bin/sh
subsonic_start() {
        if [ "$(ps |grep java | grep subsonic | grep -v grep)" > /dev/null ]; then
                echo "Subsonic already running, use restart instead"
        else
        echo "Starting subsonic..."
        sh /var/subsonic/standalone/subsonic.sh
        fi
subsonic_stop() {
        echo "Stopping subsonic..."
        kill -9 $(ps | grep java | grep subsonic | awk '{print $1}')
subsonic_restart() {
        subsonic_stop
        sleep 1
        subsonic_start
case "$1" in
'start')
        subsonic_start
'stop')
        subsonic_stop
'restart')
        subsonic_restart
        subsonic_start
esac
press CTRL+D to save file (hold done CTRL, and will still holding down CTRL push "D". Then let go of CTRL)
chmod 777 /usr/syno/etc/rc.d/S99Subsonic.sh
reboot
Optional Steps
Transcoding
mkdir /var/subsonic/transcode
ln -s /usr/syno/bin/ffmpeg /var/subsonic/transcode/ffmpeg
Must have a "hacked" bootstrap in order to do the the next few steps
ipkg update
ipkg install lame
ln -s /opt/bin/lame /var/subsonic/transcode/lame
If you dont understand any of the parts or it dont work let me no and ill see if i can help u out any
gamezonline
I wish I knew this guide existed
Postby IWarez » Sun Mar 27, 2011 6:01 pm
Ha, I wished I would have had searched the internet before I started my own installation on my DS710. Your guide would have helped me a lot.
I would like to add some extra modifications so that Subsonic displays weird (non-standard) characters too. (My Chinese source: http://shin3.blogbus.com/logs/50902661.html)
To start you need the archive gcc420_glibc236_pineview.tgz which you can download here. Save it to a folder on your NAS.
Save the following as addlocale.sh and give it execution rights. Make sure you place it in the same folder on your NAS as where you saved the file gcc420_glibc236_pineview.tgz
#!/bin/sh
echo Decompress the tarball...
gunzip -c gcc420_glibc236_pineview.tgz | tar -xvf -
echo Adding missing binaries to the system
cp i686-linux-gnu/i686-linux-gnu/bin/locale /opt/bin/
cp i686-linux-gnu/i686-linux-gnu/bin/localedef  /opt/bin/
echo Copy the needed localization info
cp -R i686-linux-gnu/i686-linux-gnu/share/i18n /usr/share
echo Making sure the locale directory exists \(Otherwise an error occurs\)
mkdir /usr/lib/locale
echo Creating the en_US.UTF-8 locale
localedef -c -f UTF-8 -i en_US en_US.UTF-8
echo The list below should contain en_US.UTF-8
locale -a
execute the addlocale.sh from within the folder where the tarball resides.
./addlocale.sh
The script does display a list of installed locales after it's ready. Make sure it contains en_US.utf8.
After the script has completed you need to add the following to the subsonic.sh file to make the locale work. I added it after the first comment block.
export LANG=en_US.UTF-8
After this you should restart subsonic to take advantage of the new locale.
Now it displays artists like Queensrÿche without problems.
Be aware that the changes you make are LOST after a firmware upgrade. You can simply rerun the addlocale.sh script after an update to make it work again.
While you are at it you might want to recompile Subsonic too. I made the following modification in the file 'subsonic-main\src\main\java\net\sourceforge\subsonic\domain\MusicFile.java' to get rid of the @eadir folders the diskstation creates in every folder. It prevents errors and duplicate albums in Subsonic.
Change this:
    public boolean isExcluded(File file) throws IOException {
        // Exclude all hidden files starting with a "."
        if (file.getName().startsWith(".")) {
            return true;
To this:
            return true;
        // Here starts the new code...
        if (file.getName().startsWith("@")) {
            return true;
        // Here ends the new code...
I hope this helps other people that want to run Subsonic on the synology NAS.
IWarez
Re: I wish I knew this guide existed
Postby gamezonline » Sun Mar 27, 2011 8:31 pm
IWarez wrote:While you are at it you might want to recompile Subsonic too. I made the following modification in the file 'subsonic-main\src\main\java\net\sourceforge\subsonic\domain\MusicFile.java' to get rid of the @eadir folders the diskstation creates in every folder. It prevents errors and duplicate albums in Subsonic.
Change this:
            return true;
To this:
            return true;
            return true;
Nice one, was going to find/make a fix for that, but got to lazy lol
gamezonline
Postby Johnny Mumble » Fri Apr 22, 2011 2:38 pm
Hi, I'm relatively new to Linux but I've managed to get subsonic up and running on my DS111. I've also downloaded the source and made the changes to hide the @eaDir folders but I'm lost at this point. I'm not sure how to compile java code in Linux, or even what to compile and then where do I put the compiled object (don't even know what I'll be getting after I compile). Any help would be greatly appreciated. Thanks.
Johnny Mumble
Postby IWarez » Tue Apr 26, 2011 7:53 pm
I used a Windows 7 machine for that. Just download apache maven and java jdk and you should be able to compile from source using maven.
IWarez
Postby n0tanumb3r » Sun Jun 05, 2011 3:37 pm
IWarez wrote:I used a Windows 7 machine for that. Just download apache maven and java jdk and you should be able to compile from source using maven.
To every one above, thanks for the pointers! Got it all up and going on a DS411+ and working very smoothly.
I too have been trying to remove the @eadir folders. Whereas my Linux knowledge is fairly sound, I can now reveal that I know less about the art of compiling software than I thought I did before starting! :cry:
I've successfully got Maven and JDK installed, but how to actually turn the source into something that I can recognise and deploy is eluding me. If anyone is able to post a hint / solution I'd be eternally grateful!
Cheers!
n0tanumb3r
Postby rivangom » Sat Jun 11, 2011 1:31 pm
Dear sir,
Can you please explain how this works.
I've downloaded the source file <subsonic-4.4-src.zip> and could find and adjust the MusicFile.java, but don't know how I should have this now into my DS1511+. It's different then the file I used for linux installation <subsonic-4.4-standalone.tar.gz> on my DS1511+. I've looked into that file but couldn't find this MusicFile.java you're referring to. This is in the file <subsonic-4.4-src.zip>.
For your understanding I've got Subsonic working on the DS1511+, but have those annoying subdirs @eaDir everywhere in my music folders.
Many Thanks!!!
Regards,
Robbert
Change this:
            return true;
To this:
            return true;
            return true;
rivangom
Postby IWarez » Sun Jun 12, 2011 6:07 pm
Gamezonline asked me to help you out with a compiled version so I put my own compiled subsonic.war on mediafire so you can download a working version. Click this link
That should help you out on the short term. Meanwhile I suggest you read up on compiling subsonic yourself. I won't be keeping this updated.
IWarez
Postby n0tanumb3r » Mon Jun 13, 2011 12:03 pm
iWarez,
You are a star. Many thanks.
Shortly before getting your post, I had managed to produce a Subsonic.war... I hadn't identified it as being what I was after though! The reading up goes on... Cheers!
n0tanumb3r
Postby primordialstew » Wed Jun 15, 2011 1:42 am
anyone know if this will work on my DS211?
thanks!
primordialstew
Postby gamezonline » Wed Jun 15, 2011 6:18 pm
primordialstew wrote:anyone know if this will work on my DS211?
thanks!
I dont beleave it will work this way on DS211 becouse its running a Marvell Kirkwood mv6282 CPU and not intel... sorry bro, ill see if i can dig up some more info about it and see what i can come up with.
gamezonline
Postby primordialstew » Wed Jun 15, 2011 7:27 pm
thanks!
primordialstew
Postby rivangom » Thu Jun 16, 2011 10:21 pm
Iwarez,
Many thanks for your contribution to this!!!! 8)
Subsonic 4.8 (build 3434) Stand-alone version on Synology NAS DS1511+
rivangom
Postby IWarez » Fri Jun 24, 2011 9:04 pm
Check the new 4.5 beta1 :) It seems the @eaDir exclusion is built-in. Yes!
IWarez
Postby gamezonline » Sat Jun 25, 2011 11:04 pm
Yup, seen that, just going to wait until at least beta 2 or 3 before i try it out, got about 12 ppl that use the server and don't want to much "down time". btw on a side not... got to love we got native vnp server support now!!
gamezonline
Return to Tutorials
