Use Keyboard Nextsong Key and Previoussong Key.
Tutorials, tips and tricks.
Postby rodb » Tue Jul 26, 2011 5:13 pm
Hello i dont know if this was already posted before but id like to share this.
You can use the keys on your keyboard to let the player go to the next or previous songs.
in /jetty/????/webapp/WEB-INF/jsp you go to playlist.jsp.
Under
<body class="bgcolor2 playlistframe" onload="init()">
You add
<body onKeyDown="showKeyCode(event)">
Under
<script type="text/javascript" language="javascript">
    var player = null;
    var songs = null;
    var currentAlbumUrl = null;
    var currentStreamUrl = null;
    var startPlayer = false;
    var repeatEnabled = false;
    var slider = null;
You add
function showKeyCode(event) {
   if(event.keyCode == 176) {
   javascript:noop();
   onNext(false);
if(event.keyCode == 177) {
   javascript:noop();
   onPrevious();
Save it and reload your browser.
This only works if the browser is an activewindow..
To check other keys add
alert(event.keyCode);
Under
Your Suggestions are welcome.
Robert :D
rodb
Postby csobsidian » Wed Aug 10, 2011 2:58 pm
I've been looking for an answer to this as well. Currently, as far as I have determined there is no way to do this easily. I do, however, plan on writing a plugin for JWPlayer that would add this functionality. Hang tight and I'll post back here when I have it completed.
csobsidian
Postby csobsidian » Wed Aug 10, 2011 5:53 pm
As I feared, the plugin ended up operating the same way. A realization should be made that this is by design. Wouldn't it be kind of nasty if I could write a flash application that silently ran in the background, recording the key strokes you made as long as you had your browser open? Speaking merely for Windows users, it would be nice to see flash be able to capture the windows messages generated by the keypress (e.g. VM_APPCOMMAND 46, VK_MEDIA_PLAY, etc.). Considering the ubiquity of multimedia keyboards and the lack of support thus far, I would say there probably isn't a workaround for the time being. I'm sure we aren't the first to want this feature.
csobsidian
Return to Tutorials
