Media Folders / 2 Drives
Frequently asked questions.
Postby ontherun » Mon Nov 18, 2013 6:36 am
I have two drives with music drives D:\Music.A-I and E:Music.J-Z
I need to have both in the same folder setup
Name = Music
Folder = D:\Music.A-I E:Music.J-Z
No matter how I address (D:\Music.A-I E:Music.J-Z) (D:\Music.A-I; E:Music.J-Z) (D:\Music.A-I / E:Music.J-Z)
I get Folder not found error. So How can I put them on the same Folder?
ontherun
Re: Media Folders / 2 Drives
Postby joost » Mon Nov 18, 2013 7:21 am
When you define music - path for drive 1 and on the second line music - path for drive 2, it should appear as 1 folder...
joost
Postby ontherun » Mon Nov 18, 2013 7:21 pm
Name Folder
Music A-I D:\Music.A-I
Music J-Z E:\Music.J-Z
The 1st drive D:\Music.A-I is correct Alphabetically A-Z
The 2nd drive E:\Music.J-Z is a 2nd folder incorrect Alphabetically A-Z
So how do I fix this?
is there away to put the path to two Drives D & E in same folder?
ontherun
Postby toolman » Sun Feb 09, 2014 12:16 pm
Perhaps you could try:
Name Folder
A D:\Music.A-I\A
B D:\Music.A-I\B
C D:\Music.A-I\C
J E:\Music.J-Z\J
Z E:\Music.J-Z\Z
I set up my Subsonic in a similar way and all folders appear in the correct Alphabetical order.
toolman
Postby lbvagrant » Thu Feb 12, 2015 6:47 am
one method might be a chore but worth it in the end and require some free space or a backup to do correctly...
either
1 format both drives as one extended partition if possible. as this makes it all on one "drive" and all done.
or
2 create the second hard drives drive letter as "none/empty folder in another drive" setting.
but this still leaves them in 2 folders witch I believe is the original issue in the first place.
I myself just spent a few bucks for a used drive for the extra space...
good luck to anyone else trying this
Sent: Thu Apr 25, 2013 12:51 am
To: lbvagrant
oh boy you are one pathetic egoistic idiot.
wow someone cant deal with a NO
lbvagrant
Return to FAQs
