How to Force User to Reset Password?
Frequently asked questions.
Postby brn2337 » Sun May 25, 2014 2:44 am
Is there a way to force a user to have to change their password the next time they log in?
Thanks for any help.
brn2337
Re: How to Force User to Reset Password?
Postby alphawave7 » Sun May 25, 2014 3:43 am
Please describe the use-case. You can as admin change the password yourself, and if the user then fails the old pw, and has permission to update his pw, this in effect is a pw reset.
Postby brn2337 » Wed Aug 13, 2014 6:30 am
Sorry for the late reply, haven't been on in a while.
For instance, if I create an account for a new user with a temporary password I would like to force them to reset their password the first time they login. I know the users can change the password manually in the Settings but most of the time they forget or are too lazy to change it and I don't want them to keep the temporary password.
Thanks for the response.
brn2337
Return to FAQs
