exported playlist cannot be read?
Frequently asked questions.
Postby megladon88 » Fri Jun 01, 2018 8:55 am
I exported a playlist from MediaMonkey to the root of the folder that subsonic views. I've tried both m3u and xspf formats. With the M3U format I get: "Failed to import playlist. No songs in the playlist were found." but the file is 34kb
For the XSPF format I get: Failed to import playlist. Failed to parse XSPF playlist.
What do I need to do to import a playlist?
Thanks in advance!
megladon88
Re: exported playlist cannot be read?
Postby Jägs » Tue Sep 25, 2018 3:43 am
Can you open the M3U file in a text editor and verify that the paths match the folder structure in Subsonic?
Jägs
Return to FAQs
