External-Player
Frequently asked questions.
External-Player
Postby Malkavien » Sat Mar 26, 2011 12:47 pm
How does it work?
The only thing i can do ist click on "play", its a javascript-Button.
Can i use Winamp or MediaMonkey or something like that?
I searched for Informations but cant find them anywhere...
Malkavien
Postby GJ51 » Mon Apr 04, 2011 2:48 am
External player will send the playlist to your default desktop player. So if your in Windows and WMP is your default, it will open and play your selections.
Postby Malkavien » Mon Apr 04, 2011 9:51 pm
no... it doesn't.
Nothing happens... I use Winamp and Mediamonkey.
But there is no Playlist, not in playlist-folder, not in any player... just like the function is called "noop".
Malkavien
Postby GJ51 » Tue Apr 05, 2011 1:52 am
What is your desktop OS?
Postby Malkavien » Thu May 05, 2011 6:22 pm
Windows 7 Prof. -32Bit
Malkavien
Postby GJ51 » Thu May 12, 2011 12:44 am
Go to Control Panel, Default Programs, Set your default programs, then select your default media player and select "Set this program as default."
Sorry I dindn't get back to you sooner.
Re: External-Player
Postby famish99 » Sat Dec 29, 2012 7:45 pm
I'm having an issue where I set subsonic to use an external player and not transcode files. Whenever there is a playlist that has both mp3 and flac files in it the player craps out going from one format to the other.
Basically the root of the problem occurs because in the stream url there's a GET variable requirement for suffix=.mp3 or suffix=.flac and when the playlist transitions from mp3 to flac files the suffix is no longer valid. I don't even get why this GET variable is necessary.
famish99
Re: External-Player
Postby famish99 » Tue Apr 23, 2013 10:04 pm
bump, can I get dev resolution about this issue?
famish99
Return to FAQs
