Subsonic conflict with Squeezebox
Frequently asked questions.
Postby Docjso » Wed Apr 06, 2011 6:29 pm
I wanted to know if there is any likely conflict between Subsonic music streaming and Squeezebox as both use iTunes?
Thankyou
Docjso
Postby M1AU » Thu Apr 21, 2011 4:06 pm
I'm not exactly sure what you mean with "both using iTunes" as I don't use iTunes at all, but I have them both running perfectly fine on my Ubuntu Server.
Subsonic is listening on port 443 (SSL), Squeezebox on port 9000. Just double check so that they're not using the same port.
M1AU
Return to FAQs
