unofficial SUBSONIC NAS COMPATIBILITY LIST
Frequently asked questions.
Postby 3R3 » Thu Jan 20, 2011 9:13 pm
I want to put Subsonic on a NAS, and was wondering on what devices all you config-fiddlers succeeded in getting SS to run on?
No Instructions on how to set it up needed, thats the job of another thread,
Just state what device (brandname and model number, maybe firmware version if you are aware of firmware that wont work), what OS on that device and what version of SS.
Also I'm not sure if this is the right forum, maybe help is more apropriate? Mods, you decide :)
unofficial SUBSONIC NAS COMPATIBILITY LIST:
    BRAND - DEVICE - NOTES
    Qnap - TS-239 and upwards - freeNAS/unRAID/any x86 linux, any subsonic (this line of NAS devices has a x86 CPU, so Java and ffmpeg is readily available) HOWTO install Subsonic on QNAP NAS (x86 based) by L4ngley
    Qnap - TS459
    Qnap - TS459 Pro (guide by Morkeleb)
    Qnap - TS-239 PROII
    Qnap - TS-119 - (Marvell ARM), slow transcoding due to no ffmpeg for ARM CPU was used/found
    Infrant readyNAS (x86 based, needs RAIDiator 4.2.14+ )(per files here: readynas.com forum: subsonic post by super poussin)
    Seagate goflex - use admin login rights
    Addonics NAS - use admin login rights
    Synology - DS1511+ - guide by gamezonline and guide by gamezonline
    Thecus - n5200 NAS - only ran after installation of a a debian lucid chroot environment, install was 'debian'.
    Western Digital - MyBook Live - using debian subsonic version, transcoders needed slight adjustment - from here
(This List will be kept up-to-date from posts in this thread as well as from what I can scrounge from other threads as best as I possibly can. Especially with info from other sources details might not always be plenty, I apologize for that.)
Thanks beforehand for anyone contributing,
3R3
3R3
Postby nestico » Mon Jan 24, 2011 7:55 am
Subsonic is running on Qnap TS-119 (Marvell ARM)
Requires installation of Sun Java Runtime Environment for Embedded. Software Floating point. Then installing Subsonic Stand-alone version (all platforms)
Still haven't figured out how to make transcoding work properly. Need an optimized aac or mp3 encoder for ARM processor. The lame encoder is too slow (about 0.5) real time.
Nestor
nestico
Postby gamezonline » Thu Feb 24, 2011 8:56 pm
got it to work on
synology DS1511+
I can post a how to if anyone wants it.
gamezonline
Postby extrafuzzyllama » Sun Feb 27, 2011 8:40 am
gamezonline wrote:got it to work on
synology DS1511+
yes please post a guide
extrafuzzyllama
Postby gamezonline » Wed Mar 02, 2011 11:01 pm
synology DS1511+
Ill work on one tonight
gamezonline
thecus n5200 nas
Postby gavinc » Thu Mar 03, 2011 7:33 pm
So, it runs on the thecus n5200 nas, albeit after I installed a debian lucid chroot environment, and did a 'debian' install.
gavinc
Postby gamezonline » Sat Mar 05, 2011 1:35 pm
synology DS1511+
here you go http://forum.subsonic.org/forum/viewtopic.php?p=22718#22718
gamezonline
Postby grimy55 » Fri Jun 03, 2011 6:51 pm
Works fine on VHS-4 from Ve-Hotech !
Just get it on the Ubuntu Server Virtual Machine and follow the classical installation instructions (http://www.subsonic.org/pages/installation.jsp#debian)
grimy55
Postby sl1000 » Tue Jun 07, 2011 6:15 pm
i've made a QPKG for easy one-click installation of Subsonic on a QNAP NAS.
Please see: http://forum.qnap.com/viewtopic.php?f=128&t=45581 for details.
I hope this will add to the popularity of subsonic :)
sl1000
Subsonic on native n5200xxx box
Postby prutser » Tue Jul 05, 2011 4:12 pm
Despite my not-knowingness I managed to install Java and the standalone version of Subsonic on my (original) Thecus N5200xxx with the latest firmware. This should run on all Thecus i386/i586 machines (Atom and Celeron procs)
Until now I have the latest version of Java available as an installable package, I have still to work on the package for Subsonic.
There is still a lot to do, Java runs now as admin, that's probably not a good idea. And there is my lack of Java knowledge, is user "nobody" a better choice? Of course I do not like to enable a security risk here ...
I understand how the packages should look like, but the code now is very ugly. Nevertheless, it works. Time will now be put on packaging Subsonic and cleaning up the code.
<Update august 14>
Java is working as an installable package (jre-6_26), Subsonic as well (4.5 build 2384). Both modules should work OK on the latest Intel based Thecus machines ... Still have to polish the code, but that seems not that important any more now it works. I've put no effort whatsoever in transcoding code like Lame, that can be done beforehand ... :D
prutser
Postby stanthewizzard » Mon Jul 11, 2011 12:13 pm
No problem on synology 411+ and 411+II
stanthewizzard
Postby Gestapo » Mon Aug 01, 2011 10:54 pm
stanthewizzard wrote:No problem on synology 411+ and 411+II
hmm. I would like it to run on my Synology DS409+.
:lol:
Gestapo
Postby Skeletor » Tue Aug 02, 2011 7:12 am
Running perfectly on headless NAS
Device - Intel SS4200
CPU - Upgraded to C2Duo E4600 2.4GHz (Originally Celeron)
Memory - 2gb (upgraded)
OS - Ubuntu 10.04 Server x64
Kernel - 2.6.32-33
Library Size - 47000 400GB+
Subsonic Info
Version 4.4 (build 2169) – February 6, 2011
Server jetty-6.1.x, java 1.6.0_20, Linux (58.0 MB / 85.6 MB)
Notes-
Java switched from IcedTea to Sun with no issues.
Works along side Serviio without problems. No problems with web, Android or Air clients. Accessing over LAN and Internet. Using https without issues.
I need to upgrade to a version of ffmpeg that I compile for other purposes so I will post back if additional flags somehow compromise SS 4.4.
Skeletor
Re: unofficial Compatibility list for Subsonic on a NAS
Postby BKKKPewsey » Sun Sep 11, 2011 5:41 pm
This very helpful thread is rather hiding here so I am moving to FAQ section
Re: unofficial SUBSONIC NAS COMPATIBILITY LIST
Postby 0d0a » Thu Nov 10, 2011 1:14 am
i am running subsonic on unraid ...
unraid installs on a memory stick of 1 gb
it boots a 4 year old dell pc with 3 ata disks
the disks form a samba share
from this share i serve my audio (and some video) ...
needed some work to get it running
a good help was http://forum.subsonic.org/forum/viewtopic.php?t=2392
have fun!
http://tepaardnaarsintpetersburg.nl
0d0a
Return to FAQs
