Another frontend, need opinions (beta release)
Postby brett » Mon Aug 16, 2010 8:17 am
burjast wrote:Really horrific solution :) Now subsonix doesn't work at all, problems with vhosts. When calling non-existing vhost ip:port/mediaplayer/music.swf file gets pulled from other wrong folder.
Server root: /
Subsonix root: stream/
when accessed via SERVER var, mediaplayer is opened from otherfolder/ location (even though access thorough ip is defaulted to /)
Strange problem, makes me dizzy :) Find another solution please, when changing var with vhost, page doesn't even fully load, so at this time I don't have solution for this.
For now just edit that line directly, and put in your server address manually, instead of javascript doing it, say that juke.php was located here: http://www.serverip.com:port/stream/juke.php , do this
swfobject.embedSWF('http://www.serverip.com:port/stream/mediaplayer/'+type+'.swf', 'player', w, h, '9', 'swfobject/expressInstall.swf', flashvars, params, attributes);
But replace it with your server address/port/directory
brett
Postby burjast » Mon Aug 16, 2010 8:26 am
stream is vhosted, directly on subdomain, so
stream.domain.com/mediaplayer/+'type...
but whatever i implement, page is broken:
Cannot redeclare logged_in() (previously declared in functions.php on line 6)
logouting doesn't help solve this problem
I just know.
burjast
Postby brett » Tue Aug 17, 2010 12:57 am
burjast wrote:stream is vhosted, directly on subdomain, so
Try not to download any of the singular files right now, grab the zips that have been tested please
brett
Postby kenz » Mon Oct 11, 2010 8:09 pm
it looks to be a very good work !!
(pls don't see the following as offensive talks)
but we need to be a super-computed-networks engeener from the MIT to understand how to install it :)
at this time it just f***ed up my normal subsonic install.....so I will just enjoy your nice screenshots and be jealous :) :) :)
:cry: :cry:
kenz
Postby soonerrob » Tue Oct 12, 2010 2:39 pm
Ive got the script working... only 1 thing wrong...
some of the graphics are not showing up... the background images.. the icons on the top buttons...
not sure what is causing this.
something else i overcame... i couldnt get the install script to connect to my subsonic server... tried for over an hour...
finally i thought it might be username and password, because the password for this particular login had !#@$ type characters...
made a new login with standard characters and it connected perfectly.
here is a screenshot of my image problem..
soonerrob
Postby brett » Wed Oct 13, 2010 6:25 am
soonerrob wrote:Ive got the script working... only 1 thing wrong...
Look in js/juke.js, there should be some lines similar to this
$('#menu .headerimgset').eq(0).css("backgroundImage","url('img/0.png')");
It should be this:
            $('#menu .headerimgset').eq(0).css("background","url('img/0.png')");
            $('#menu .headerimgset').eq(1).css("background","url('img/1.png')");
            $('#menu .headerimgset').eq(2).css("background","url('img/2.png')");
            $('#menu .headerimgset').eq(3).css("background","url('img/3.png')");
            $('#menu .headerimgset').eq(4).css("background","url('img/4.png')");
            $('#menu .headerimgset').eq(5).css("background","url('img/5.png')");
I fixed this in a later version but have yet to release the full script as I'm still working on a better setup script, which the login test you mentioned later should also be fixed. Let me know if this works
brett
Postby kingmos » Thu Oct 14, 2010 2:54 pm
First of all - great work!
I've got the same problem, no images. And css seems messed up too. I don't have a file called juke.js, any suggestions? Latest version, downloaded an hour ago.. Running on Apache
kingmos
Postby brett » Sat Oct 16, 2010 7:27 am
kingmos wrote:First of all - great work!
Sorry it took so long to respond, could you tell me the name of the root album there(the one that shows only the '#' symbol? I didn't do many checks for invalid characters and I feel that may be the issue.
As for the images, I actually separated the javascript in a newer version that has not been released yet, the portion you are looking for is in juke.php.
$('#menu .headerimgset').eq(0).css("background","url('/img/0.png')");
            $('#menu .headerimgset').eq(1).css("background","url('/img/1.png')");
            $('#menu .headerimgset').eq(2).css("background","url('/img/2.png')");
            $('#menu .headerimgset').eq(3).css("background","url('/img/3.png')");
            $('#menu .headerimgset').eq(4).css("background","url('/img/4.png')");
            $('#menu .headerimgset').eq(5).css("background","url('/img/5.png')");
should be
It doesn't look like the visualization is working either, I had issues when connecting locally if the script was setup to route through a public IP or vice versa.
brett
Postby mieloup » Fri Nov 12, 2010 10:13 pm
First I can't tell you if it's a good work (cause it doesn't work for me ) but look'like ;)
I've got this message
' Script variables look setup, create the database if you haven't already, then configure your music/video folders ' and every thing looks fine but I can't congigure my folder : I select them and then nothing ...
Can you help me ?
Thx :)
mieloup
Soma.fm
Postby rasputinschild » Tue Nov 16, 2010 3:27 pm
Hey Brett,
Supersonic looks great, I see you've got built in DI.fm stuff, would you consider adding the Soma.fm streams?
Nowhere else can you get a stream of secret agent music.
rasputinschild
Postby jayknow05 » Tue Nov 23, 2010 5:33 am
I've managed to get the settings.php file complete and correct, although I had to manually build it for some reason setup wasn't saving the file.
Anyways, now when I load the juke.php file I just get a blank page. I put in a couple echos and it seems like it is choking on the database, which seems to be working correctly. Any suggestions?
<?php
   require_once(getcwd()."/includes/connection.php");
   $result = $sonic->query("SELECT * FROM users") or die("Jukebox not <a href='/setup.php'>setup</a>");
   $result = "SELECT * FROM users WHERE username = '".$_SESSION['username']."'";
   foreach($sonic->query($result) as $row) {
      if ($row['admin'] == 1) define('ADMIN','1');
      else define('ADMIN','0');
It seems to get stuck early on in this block of code. NOTHING shows up, not even Jukebox not setup.
jayknow05
Postby jayknow05 » Wed Nov 24, 2010 2:12 am
I got through my "settings.php" file and FINALLY made it to "login.php". There was an error in the "form_functions.php"
Replaced
function display_errors($error_array) {
   echo <p class=/"errors/">";
   echo "Please review the following fields:<br />";
   foreach($error_array as $error) {
      echo " - " . $error . "<br />";
   echo "</p>";
This line is just escaped wrong:
   echo '<p class="errors">';
   echo "</p>";
jayknow05
Postby frankspin » Wed Nov 24, 2010 5:27 pm
Forgive my ignorance with this question. I read over Bret's install and the one posted on page 3 before posting this.
Can this be installed over the current Subsonic setup or does it need mysql or WAMP to work?
I have subsonic running on a HTPC and am trying to minimize resource overhead on it.
frankspin
Please keep me in the loop!
Postby cosmicdave » Wed Nov 24, 2010 7:57 pm
Please let me know when it's released...looks really nice!
cosmicdave
Postby ccandreva » Fri Nov 26, 2010 10:21 pm
Is the download link still http://www.valleynerds.com/brett/ ?
www.valleynerds.com doesn't seem to be responding.
ccandreva
