I've not got a Mac so can't verify where everything goes, but I believe the following should work:
Go to: /Library/Application Support/Subsonic/jetty/<num>/webapp
Unzip the the subtunes zip file there so the path to the code in the zip is:
/Library/Application Support/Subsonic/jetty/<num>/webapp/subtunes/
That should be all. Then hit:
http://localhost:
And it should work. Let me know if it does and I'll update the docs on the site.
mgrant wrote:Here's how I got it to work for me on standalone subsonic.
First some background:
subsonic is installed in /var/subsonic
subsonic is accessed at http://192.168.xxx.yyy:8080/subsonic
Following the instructions from mattgoldspink I extracted the subsonic-0.8.1.zip to /var/subsonic/jetty/<num>/webapp. This created /var/subsonic/jetty/<num>/webapp/music.
To access subtunes I can browse to http://192.168.xxx.yyy:8080/subsonic/music.
Other than the previously reported slowness issues (I have a large collection) it seems to work great!
mattgoldspink wrote:Is this with Safari? If so it turns out there's some known issues with it and the soundmanager library I use:
http://code.google.com/p/subtunes/issues/detail?id=17
Could you try opening the file subsonic-viewport.js and removing the line:
soundManager.useHTML5Audio = true;
(should be the second line)
Let me know if that helps at all.
