Subsonic Pack version 4.4- 2172
Postby cyclopes » Thu Mar 03, 2011 8:24 pm
working on it now ;)
thanks for the info
sanderd wrote:Hi cyclopes,
what is the issue with building prev. next buttons for the jukebox player?
(didn't show up in searching this forum)
i mainly use the webinterface with jukeboxplayer because my home server is connected to an usb DAC on my stereo.
with current webinterface both the size/location of the playlist and skipping through playlist is not very well designed. i rather have the playlist at the right column to see more songs without having to scroll.
thanks.
Vote Confirmation ;)
cyclopes
Postby 3R3 » Sat Mar 05, 2011 6:03 pm
I was looking at a thread requesting more admin controls the other day, so I went and added a little user/admin "recognition" to "the Packs" upload window. And why not share it with the world:
In admin mode, the full destination path can be edited (dangerous!) and you get to decide whether zipped stuff should be auto-extracted after upload.
In user mode and with upload right, destination path will be <music path>/Incoming/<username> and the user will not see the path. he can select a file or zip to be uploaded, but cannot decide whether zips should auto-extract. they will per default and the checkbox is invisible.
The screenshots roughly reflect the code.Though the layout is still the same, I tweaked it a bit for convenience. I removed the german ;) And the heading "User interface" too, was confusing and a bit belittling ;)
Admin view:
User view:
To install:
1. BACKUP
2. shut down subsonic
3. open moree.jsp in subsonic/jetty/xxxx/webapp/WEB-INF/jsp and find
<c:if test="${model.user.uploadRole}">
    <h2></h2>
    <form method="post" enctype="multipart/form-data" action="upwin.view">
        <table>
            <tr>
                <td><fmt:message key="more.upload.source"/></td>
                <td colspan="2"><input type="file" id="file" name="file" size="40"/></td>
            </tr>
            <tr>
                <td><fmt:message key="more.upload.target"/></td>
                <td><input type="text" id="dir" readonly="readonly" name="dir" size="37" value="${model.uploadDirectory}/${model.user.username}"/></td>
                <td><input type="submit" value="<fmt:message key="more.upload.ok"/>"/></td>
            </tr>
            <tr>
                <td colspan="2">
                    <input type="checkbox" checked name="unzip" id="unzip" class="checkbox"/>
                    <label for="unzip"><fmt:message key="more.upload.unzip"/></label>
                </td>
            </tr>
        </table>
    </form>
    <p class="enter" id="progressText"/>
    <div id="progressBar">
        <div id="progressBarContent"/>
    </div>
</c:if>
replace with
<!-- Upload Windows for normal users -->
<c:if test="${model.user.uploadRole and not model.user.adminRole}">
    <h2></h2>
        <table>
            <tr>
                <td><input type="file" id="file" name="file" size="40"/></td>
            </tr>
            <tr>
                <!-- <td><fmt:message key="more.upload.target"/></td> -->
                <td><input type="hidden" id="dir" name="dir" size="37" value="${model.uploadDirectory}/${model.user.username}"/></td>
                <td><b>You can upload single files and zipped folders. Zipped folders will be automatically extracted.</b></td>
            </tr>
            <tr>
                <td colspan="2">
                    <input type="hidden" checked name="unzip" id="unzip" class="checkbox"/>
                    <!-- <label for="unzip"><fmt:message key="more.upload.unzip"/></label> -->
                </td>
            </tr>
        </table>
    </form>
    </div>
</c:if>
<!-- Upload Win for Admin -->
<c:if test="${model.user.adminRole}">
    <h2>Admin Interface</h2>
        <table>
            <tr>
            </tr>
            <tr>
                <td><input type="text" id="dir" name="dir" size="56" value="${model.uploadDirectory}/${model.user.username}"/></td>
            </tr>
            <tr>
                <td colspan="2">
                </td>
            </tr>
            <tr><td colspan="3"><b>You are admin, you already know everything I could possibly print here.</b></td></tr>
        </table>
    </form>
    </div>
</c:if>
4. save file
5. clear jetty cache
6. start subsonic
This is based on my own modification of cyclopes SS pack. I left anything from his original mod mostly intact, just commented some stuff out so you can easyly restore to that layout or just change little bits.
awaiting feedback :)
3R3
Postby benzubi » Sun Mar 06, 2011 11:24 am
hey
Ive been waiting for this cyclopes, gonna try it out now.
thanks ! :shock:
benzubi
Postby cyclopes » Sun Mar 06, 2011 11:04 pm
:D
benzubi wrote:hey
thanks ! :shock:
cyclopes
Postby cyclopes » Sat Mar 12, 2011 12:27 am
New update is on its way, there were some problems with buttons that crashed in the jukebox player..
cyclopes
Postby benzubi » Sun Mar 13, 2011 10:33 pm
Never had the issue, worked great here. 8)
benzubi
Postby bozolino » Sat Mar 19, 2011 3:16 pm
thanks so much for this!
one problem though: when i click "Upload", the resulting popup has a black background and almost-black (very dark grey) text... so i can't read the text.... [see screenshot below]
is there any way to change that?
thanks in advance!
bozolino
Postby muiz » Tue Jun 07, 2011 11:55 pm
works fine but not the player skin still shows the old one
muiz
Postby cyclopes » Wed Jun 08, 2011 12:04 am
muiz wrote:works fine but not the player skin still shows the old one
Try this:
stop subsonic.
you have upload this files:
playlist.jsp --> Only open file in Notepad and save
home.jsp --> Only open file in Notepad and save
main.jsp --> Only open file in Notepad and save
more.jsp --> Only open file in Notepad and save
Regards
Cyclopes
cyclopes
Postby muiz » Wed Jun 08, 2011 12:25 am
i did , and i also opened them all and saved.
but it shows only the extra buttons , but there is no more player.
i also tried 3R3's changes, but that screwed it all up more badly
muiz
Postby cyclopes » Wed Jun 08, 2011 5:24 am
muiz wrote:i did , and i also opened them all and saved.
try ccleaner
http://www.filehippo.com/download_ccleaner/
cyclopes
Postby muiz » Wed Jun 08, 2011 11:36 am
thx that did the trick
muiz
Postby muiz » Wed Jun 08, 2011 1:17 pm
One more question.
How i put all items on the same height here :
muiz
Postby cyclopes » Wed Jun 08, 2011 8:31 pm
muiz wrote:One more question.
Have you added the equalizer on playlist.jsp
if you have you must open playlist and look at height: px and add in the playlist .
<img src="icons/ ______
example:
<c:if test="${model.player.web}">
<td valign="bottom" style="height:35px;padding-left:0px;padding-right:0px"><a href="javascript:noop()" onclick="onPrevious()"><img src="icons/rewind1.png"/></a></td>
<td valign="bottom" style="height:35px;padding-left:0px;padding-right:0px"><a href="javascript:noop()" onclick="onNext(false)"><img src="icons/forward1.png"/></a></td>
</c:if>
and
next
cyclopes
Postby muiz » Wed Jun 08, 2011 9:35 pm
I have lowered the player for the EQ , but now i want the rest lower to.
muiz
