djetch wrote:Okay. I am starting with a fresh install of everything OS, Subsonic, this MOD and I'm still running into trouble....I'm going to do it all over again just to make sure I didn't miss something or whatever.
-Right now as it stands I've the following setup:
Ubuntu 12.04 64bit server (running in a VM if that matters)
Subsonic 7.4beta
Mashup MOD 4.7 (lastest build)
Granted this time everything seemed to go smoothly with the install and I was actually sitting at the log in screen. Got in with the normal defaults....now if I try and do much of anything it just drops me right back at the log in screen. So frustrating.
But, I'll blow out the VM and start over!
EDIT: Restarted my Ubuntu server and now Subsonic won't start at all it just gets hung on the fact that it can not find/get the theme it wants "MadSonic_dark". The more I try, the less I seem to understand with this thing....Should I just run this on an apache server or something? How do I get the theme/skin? In the first post what are the links to the base system and combined version for??? So many questions....Yet I read post after post about how much people love this MOD...I must just be stupid or something.
I hope i killed all bugs with the new Build and installer packages.
Short Instruction for new/existing Ubuntu installation:1. Fresh Ubuntu 12.4 Install
2. Install Java 1.7
3. Config current JRE to 1.7 with:
sudo update-alternatives --config javac sudo update-alternatives --config java 4. check config with
javac -version5. Start Firefox and Check Java Version
browse ->
http://javatester.org6. Install Adobe Flash Player
7. Uninstall all current subsonic version
8. If exist delete folder
/var/subsonic9. Create
/var/music folder
10. Put Content into
/var/music11. Install subsonic Mashup Mod (.deb)
12. Check if Service is running
sudo service subsonic start13. Start Firefox
browse ->
http://localhost:404014. Config subsonic via Webpage
15.
Done! I am confident that this helps!
Best regards
