Subsonic Player Mod
sure
Postby trickydick » Fri Aug 05, 2011 8:50 pm
if you like you can make the width not 100%. Edit this in the playlist.jsp
<div id="mypanel" class="ddpanel">
to
<div id="mypanel" class="ddpanel" style="width:80%;">
or to
<div id="mypanel" class="ddpanel" style="width:750px;">
something to your liking. I perfer px instead of percent, its more constant.
Tricky
trickydick
Re: Subsonic Player Mod
Postby Ultraviolet » Wed Aug 17, 2011 8:13 pm
I'm using this player mod with your outlook theme and am really enjoying it. However, I am just trying video for the the first time and can't figure out how to share a video with the new v4.5 feature. Audio works fine, I just don't see the option to share video.
I may be missing something obvious or asking in the wrong place, but since I don't see other questions related to video sharing on the forums, I was wondering if this player mod or outlook theme was somehow obscuring this functionality. Has anyone had any luck sharing video? Am I being dense(r than usual)?
Ultraviolet
Postby BKKKPewsey » Wed Aug 17, 2011 9:10 pm
I dont have the outlook theme but the share button is next to the facebook and twitter icons on mine.
e.g. the same place as with audio files
Postby Ultraviolet » Wed Aug 17, 2011 9:17 pm
Ahh, so the Outlook theme seems to be quite different--which is why I like it though. I also have done some further work on the theme myself and removed the Twitter and Facebook share options. I can still share audio fine so I made the assumption that I didn't cut too deeply into the code, but I'll double check what I did while I wait for trickydick to chime in.
Ultraviolet
Postby trickydick » Thu Aug 18, 2011 3:05 am
the share button is in the advanced menu as well.
Tricky
trickydick
Postby trickydick » Thu Aug 18, 2011 3:25 am
the outlook themes have change a little (for the better), take a look:
http://forum.subsonic.org/forum/viewtopic.php?f=8&t=7238&p=30390#p30390
Tricky
trickydick
Postby Ultraviolet » Thu Aug 18, 2011 4:47 am
Sorry, I wasn't being very clear in my description. The button you circled works for any tracks that are listed in the playlist frame, but video does not play in that frame, nor does it list the video track in that frame (at least not for me), so the share generated is blank (i.e. creates a functioning link, but that link has nothing to play).
Ultraviolet
Postby BKKKPewsey » Thu Aug 18, 2011 10:40 am
That button work for me but that was because I only had 1 vid in that folder.
If you have more than one then do the following.
Works for me 8)
Postby trickydick » Thu Aug 18, 2011 2:58 pm
I see, then yes BKKKPewsey is right. Although, in the outlook theme, I removed the dropdown and placed the single share button on top along the rest of the options, but then i relized I was missing two other buttons (select all/none) and added those as well. To me dropdowns just seem like to much clicking....oh and i removed the facebook/twitter links as they are useless because they are the same shareurl as the share link, why have two extra links? I've also remove the third instance of the star ratings. Here is a look:
Select all:
changes to Select none (when clicked and visa versa)
I have not released this theme version yet....soon
Tricky
trickydick
Postby BKKKPewsey » Thu Aug 18, 2011 3:49 pm
trickydick wrote:...oh and i removed the facebook/twitter links as they are useless because they are the same shareurl as the share link, why have two extra links? I've also remove the third instance of the star ratings. Here is a look:
I would not say they are useless as the do link to your facebook or twitter page directly.
I am a bit confused about the third instance of the star rating as I have only two shown on mine :?
Nice looking theme though (although not for me I prefer the dark side :twisted: )
Postby Ultraviolet » Thu Aug 18, 2011 4:20 pm
Thanks for the help guys. Looking forward to the new theme release.
Ultraviolet
Postby trickydick » Thu Aug 18, 2011 6:15 pm
i think the tird one came when i copied code from the orginal files. i don't see it either anymore.
dark side....have you tried the outlook black theme?
Tricky
trickydick
Postby muiz » Sat Aug 20, 2011 8:51 pm
cant get it to work in 4.5
muiz
Postby trickydick » Mon Aug 22, 2011 9:57 am
Why? Whats the problem? Be sure to stop the services and clear any cache. Sometimes i find it help full to open the theme .properties files and save them manually. this way the files modified date changes and the server will pick it up as new and load them into memory. Let me know what I can do to help...
Tricky
trickydick
Re: Subsonic Player Mod v4.0
Postby trickydick » Thu Aug 25, 2011 1:25 am
I cannot believ i missed some much in this mod. I left out an essential script, left unused scripts and had them linked. I'm such an idiot. here is a new and improved mod...sorry
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B1iBWlUz8eUkYjQ2NTVkNTctMGI3Yi00N2VkLWIwOTgtOWEzMWEwYWJkZjBh&hl=en_US
Tricky
trickydick
