Chrome app: Perisonic (Android app update)
Re: Chrome app: Perisonic (Android app update)
Postby boognish43 » Mon Nov 05, 2012 9:53 pm
Is there anyway you can add a feature to exclude certain artists? I have 1 artist 20,000+ tracks so thats mostly what gets played even though i have a ton of other music.
thanks for creating this, so far it has been awesome!
boognish43
Postby heehoo » Wed Feb 05, 2014 12:02 pm
It has been a long, long, loooong time, but here is a small update again for the Perisonic Chrome app. I couldn't easily update the Chrome app earlier, as the permissions system in Chrome was changed. Now it's a hosted app, so you can also use it within your browser directly via http://www.robinbakker.nl/perisonic
Update 2.0.2:
- This is a hosted app now (required for extension permissions)
- Keyboard shortcuts for pause (space bar), prev (left arrow), next (right arrow)
- Script updates & bug fixes -> donate button is working now! :)
heehoo
Postby blakesteve » Tue Feb 25, 2014 10:42 pm
Greetings!
With Perisonic, for the last several weeks, I've received this error:
Error while connecting to the server.
I've not had issues prior, and I can still access my server normally through the browser (http://squares.subsonic.org)
Any clue, or anybody else getting this issue?
blakesteve
Postby blakesteve » Tue Feb 25, 2014 11:03 pm
Also, I updated to subsonic 4.9 recently as well, so it may be a compatibility issue with the version.
blakesteve
Postby heehoo » Wed Mar 12, 2014 9:59 pm
@blakesteve
Thank you for your feedback. However, I haven't been able to reproduce the problem yet (I'm using Subsonic 4.9 too). When you click the Perisonic logo at the top, are you able to get to the "About" tab? Could you try to reset your local storage by clicking the link "Clear local storage" there? Then you will have to setup the server connection again, but maybe this "resets" any existing issue.
heehoo
Postby ebasta » Tue Sep 16, 2014 10:13 pm
Hello - could you add a screen resolution option to the settings - on a 27" I cannot see text or images and the background sometimes seems to hang the browser. Thanks!
ebasta
Postby ebasta » Fri Feb 20, 2015 8:08 pm
I use this android app a lot, but it is way too small with the current resolution on a Oneplus One. Could someone repackage this with a more compatible resolution?
ebasta
Postby acroyear » Mon Mar 02, 2015 6:44 pm
re: the connect-to-server for 4.9? I found that 4.9 had a bug in its CORS headers when I was writing SubFire. The only consistent fix was to just upgrade to 5.0 which resolved it.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Previous
