evanrich wrote:wow. This looks like a commercial grade app. looks really well done, congrats!
Waro555 wrote:Hello Paul,
I found a little bug.
If I add few songs to the Playlist, press play, the music start. Now I open the playlist and remove song one by one (using X button), the playlist is now empty ... the last song is still playing (no problem ...). Then now if I browse for a new song, select one, double click for the preview, then the song start while the one from the playlist is still running. You have two songs running at the same time. When quitting the program i see an error from windows too.
Cheers !
Waro555 wrote:Maybe a button that clear the whole playlist at once and stop the player may do the trick ?
Waro555 wrote:So if you want to develop something to let us select the Folder to browse as you propose i would love it.
rino655 wrote:Is this application able to access a https subsonic address? I have been trying but had no luck connecting.
Aethies wrote:Very nice indeed! I can't get past the error message that it can't get past the secure connection. I used both, http://xxxx.subsonic.org and ip, with and without port.
Looks very nice tho! Will keep checking back for updates!
EDIT: Added attachment of error.
Is your subsonic setup to use https also?
Paul
Aethies wrote:Yes. I forgot to add that fact. And yes, I tried https as well.
