mattgoldspink wrote:The way the grid works is it recursively gets all tracks from all sub directories based on the current folder you clicked in the tree. Does that sound like the behaviour you're seeing? If not could you give me a better idea of how you folders are structured and what you expect to see (do you use symlinks or anything like that?)
GJ51 wrote:I would be carefull about getting too deeply nested in a complex file storage structure. At some point there is a limit either in the OS or the program that will cause problems.
nickles wrote:Hi,
Thanks for developing this interface. It looks really awesome.
Unfortunately, I'm encountering a problem launching this site. I have subsonic loaded at http//mydomain.com:8080 and I'm launching subtunes from http://mydomain.com:8080/subtunes. I can't get past the window prompting me to enter the path to my subsonic server despite entering http://mydomain.com:8080.
Do you have any suggestions on fixing this?
Thanks.
stueyboy wrote:nickles wrote:Hi,
Thanks.
Try another / on the end
HTTP ERROR: 404
NOT_FOUND
RequestURI=/subtunes/
Powered by Jetty://mattgoldspink wrote:HI all,
Sorry for the delay in replying for some reason I stopped getting notifications of updates to the thread:
@lprager@compup.com
I suspect this is because I was working around a bug in the playlist api in 4.2 which I reported to Sindre and he's since fixed. I'll take a look to get it working on 4.3 now it's released
@stueyboy
Is there anyway you could set me up a temporary account on your server so I could see what's going on? If that's possible just PM me the details and I'll take a look. As for the player issue back in the proper subsonic disappearing, I've seen this but I've not had time to figure out what's going on. I've added an issue to remind me to look into it: http://code.google.com/p/subtunes/issues/detail?id=52
@nickles @liquiddiet
What happens if you hit http://mydomain.com:8080/subtunes/index.html? (@liquiddiet try http://localhost/subtunes/index.html in your case) I'm wondering if the server doesn't automatically redirect to index.html for you.
