Similar Artists Javascript Widget Mod
Re: Similar Artists Javascript Widget Mod
Postby Hellscream » Wed Dec 28, 2011 10:18 pm
This is very strange I use similar artist from very beginning and its a part of my SS, after i upgrade to SS 4.6 i have problem starting this widget and believe me i try everything.
Can someone help me with this problem
Hellscream
Postby BKKKPewsey » Wed Dec 28, 2011 11:46 pm
Hi Hellscream
Long time no hear? here ? :D
I am running 4.6 with this mod NP (thank you mqchen)
This and the EQ mod are the only ones I have implemented at that moment so perhaps your mods are clashing? :?
Postby mqchen » Wed Dec 28, 2011 11:47 pm
@Hellscream
Obvious stupid question: Did you try re-installing the widget (i.e. copying everything again)?
mqchen
Postby Hellscream » Wed Dec 28, 2011 11:58 pm
thx for fast reply yes i install all from beginning i even download latest version .
I start to suspect that my server have some issues i will try another link for host .
Hellscream
Postby mqchen » Thu Dec 29, 2011 12:05 am
Another stupid obvious question: Did you restart your subsonic server?
If you've done that, could you open up Firebug and see if we get any errors?
mqchen
Postby Hellscream » Thu Dec 29, 2011 12:15 am
@pcace nop that doesnt help at all
can someone test my host at least i will eliminate something
http://hellscream.dyndns.org/ArtistInfo/jsonp.php
thx in advance
@mqchen
i dont have firebug installed kinda lazy to do that tonight
Hellscream
Postby Hellscream » Thu Dec 29, 2011 12:22 am
i mean to replace link in similar_artists.js with link i post and check does it all working fine
line 81 var url = 'http://hellscream.dyndns.org/ArtistInfo/jsonp.php';
Hellscream
Postby Hellscream » Thu Dec 29, 2011 12:28 am
Rly appreciate your help this is very important widget for me :P
But if everything work on your side with my host problem might be customized index.jsp file :(
Hellscream
Postby Hellscream » Thu Dec 29, 2011 12:32 am
O man ty for testing now im pissed i need to fix this
Hellscream
Postby Hellscream » Thu Dec 29, 2011 12:42 am
I use a lot of customization from forum i think i make some mistake while i upgrade to 4.6 but your help is huge at least i know that host is OK rest is just a matter of time.
If u have time later or another day check work of many ppl from forum at http://hellscream.subsonic.org atm offline
cheers m8
Hellscream
Postby Hellscream » Thu Dec 29, 2011 12:47 am
GN m8 have a sweet and wet dreams :)
Hellscream
Postby Hellscream » Thu Dec 29, 2011 1:54 am
YEY it's alive it's alive :) damn curl and server autoupdate
everything is OK now
Hellscream
Postby Hellscream » Thu Dec 29, 2011 10:57 am
Add host to your server if you have it or use another, i think its pretty stable when you make him work 1st time
Hellscream
Postby BKKKPewsey » Thu Dec 29, 2011 4:46 pm
One thing to check is do NOT use IE9.
I have never managed to get the SA mod to work with that browser - FF and chrome no problem.
Postby Hellscream » Thu Dec 29, 2011 5:22 pm
SA working fine with safari
Hellscream
