How to change the front page?
Postby arcadia » Fri Aug 31, 2012 11:59 am
:D Hello :D
A tutorial :?:
Assistance :?:
8) thank you for your help
:arrow: Yours
détresse
Pour modifier la page ou j ai mis l'image
Ex:, ajouter mon code php ou html5 ou code javascript à placer
brièvement changer la page de connexion avec quelque chose de plus personel windows seven 64 bits quatre principaux 3,7 16G de mémoire Disque dur 2 terra subsonique 4.7. beta3 (build 3081) - Août 3, 2012 merci bon pour vous
arcadia
Re: How to change the front page?
Postby BKKKPewsey » Fri Aug 31, 2012 12:57 pm
arcadia wrote:How to change the front page?
In what way :?
Colour - change default theme?
Text -Settings/General - Login message?
Postby bushman4 » Fri Aug 31, 2012 1:21 pm
And what operating system and platform are you running?
All these questions matter...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby arcadia » Fri Aug 31, 2012 6:23 pm
distress
To change the page or j have put the image
For ex:, add my code html5 or php or javascript code to place
Briefly change the login page with something more personel
windows seven 64 bit four core 3.7 16G memory Hdd 2 terra
subsonic 4.7.beta3 (build 3081) - August 3, 2012
thank you
good to you
arcadia
Postby GJ51 » Fri Aug 31, 2012 11:40 pm
You should be reading and asking around in the "Mods" section of the forum.
Postby hakko » Sun Sep 02, 2012 2:40 pm
Edit the file login.jsp, found under C:/Subsonic/jetty/$[BUILD_NUMBER]/webapp/WEB-INF/jsp/login.jsp
MusicCabinet developer
hakko
Users browsing this forum: Google [Bot] and 9 guests
