linux subsonic + musiccabinet
Re: linux subsonic + musiccabinet
Postby TrezOne » Wed Sep 09, 2015 1:57 am
When you're saying no sign of MusicCabinet anywhere... care to elaborate?
TrezOne
Postby innerspaceboy » Wed Sep 09, 2015 12:15 pm
Certainly. The installation guide for MusicCabinet states:
Start and log in to Subsonic as usual (normally via localhost:4040) and click the big "Configure MusicCabinet" header link. It should be pretty self-explanatory from there.
But after following the process and logging in, no big header link was visible.
Here's a snapshot of Subsonic after I log in.
I've tried Chromium and Firefox but do not see a header.
Might I have missed something?
innerspaceboy
Postby innerspaceboy » Thu Sep 10, 2015 2:01 am
I did a bit more research and started from square one. I suspected that I might have an incomplete/incorrect installation of Postgresql.
The MusicCabinet installation guide directs users to http://www.postgresql.org/download which has an Ubuntu installation page - http://www.postgresql.org/download/linux/ubuntu/. The page instructs the user to enter:
apt-get install postgresql-9.4
Doing so returns the following error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package postgresql-9.4
E: Couldn't find any package by regex 'postgresql-9.4'
Still, a note on the page indicates that "PostgreSQL is available in all Ubuntu versions by default."
The MusicCabinet installation page also states that some Linux users may need to enter:
sudo apt-get install postgresql-contrib
Doing so returns the following:
postgresql-contrib is already the newest version.
The following packages were automatically installed and are no longer required:
  comerr-dev krb5-multidev libgssrpc4 libkadm5clnt-mit9 libkadm5srv-mit9
  libkdb5-7 libpq-dev libssl-dev libssl-doc zlib1g-dev
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
Based on the info above, it appears Postgresql is succesfully installed.
guisar's instructions (posted to this thread Tue Jan 15, 2013 2:15 pm) direct the user to set up their Postgresql pwd next.
Entering sudo -u postgres psql template1 successfully takes me through each of the subsequent steps to set up a password.
I made sure to replace the two specified files as instructed, then restarted Subsonic and logged in.
Still no MusicCabinet menu and the Subsonic log is as per usual.
I welcome your input.
innerspaceboy
Previous
