editing the login page
Postby dr3van » Mon Jan 14, 2013 8:44 pm
I am trying to edit the login page, but after editing the /var/subsonic/jetty/####/webapp/WEB-INF/jsp/login.jsp I am not seeing any changes I have made?
I have been able to edit the index.jsp & top.jsp to mod the install to my likings, but not able to edit the login page...
In my old install it was modded and I tried to mod it in the same fashion with no luck. I am not sure what has changed or if I am missing something, no matter how my login.jsp looks on the server when I go to the site it is always the default? Even if I mod it, save it reboot the server and go to https://dr3van.com and then view page source it is showing the original login.jsp not the edited one?
What I am trying to do is install the registration mod which I had running on my last server before it died. I am asking here because I don't believe my problem is with the registration page because all the back-end is working fine. I just can not get the login.jsp to show any changes made to it...
Any help would be most appreciated! Thanks in advance!
Subsonic Server: https://dr3van.com
build
Ubuntu Server 12.10 64 bit LAMP
Subsonic 4.7 custom
dr3van
Re: editing the login page
Postby gurutech » Tue Jan 15, 2013 12:35 am
you need to clear the server cache. I posted the path on your other post.
gurutech
