Can't logon to MusicCabine v0.7. Why not?
Postby SoniXnSubs » Thu Jun 27, 2013 6:35 pm
Problem: Can't logon to newly installed MusicCabinet v0.7. What to do?
Others have posted similar, we need the solution...
My setup:
OS: Windows XP Home Edition version 2002, SP 3 (I know. The only OS I've got :- )
PC: Dell Dimension XP061, 2,4GHz, 2,75GB RAM
Subsonic v4.8 (Proud Paying Premium : )
PosgreSQL v9.3beta1 Reports it is running a database called "postgres" on port 5432. Username (couldn't change at install) is also postgres. I had to provide a password. I can log on with it. I'm wondering how SubSonic/MusicCabinet knows that password???
MusicCabinet v0.7. Installed using the Windows installer
Instructions are to
- install PostgreSQL 9.1 or above
- database user (defa) "postgres" (couldn't chose other, had to provide password. Any is ok?)
- port number (defa) "5432"
- run windows installer of MusicCabinet
- use stand-alone version of SubSonic
Install files used:
(53 583 104 bytes) postgresql-9.3.0-beta1-windows.exe
(37 723 778 bytes) subsonic-4.8-setup.exe
( 7 850 894 bytes) subsonic-musiccabinet-0.7-setup.exe
Standalone:
(30 104 243 bytes) subsonic-installer-standalone.zip
I've tried using the Subsonic standalone and the installed instance, but they both fail. They both give me this error on http://localhost:4040
Exception: org.springframework.jdbc.BadSqlGrammarException
Message: PreparedStatementCallback; bad SQL grammar [select username, locale, theme_id, last_fm_enabled, last_fm_username, transcode_scheme, show_now_playing, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, album_order_ascending, album_order_by_year, default_home_view, default_home_artists, default_home_albums, default_home_songs, artist_grid_width, album_grid_layout, related_artists, recommended_artists, reluctant_artist_loading, only_album_artist_recommendations, various_artists_shortlist, view_stats_for_all_users from user_settings where username=?]; nested exception is java.sql.SQLException: Column not found: ALBUM_ORDER_ASCENDING in statement [select username, locale, theme_id, last_fm_enabled, last_fm_username, transcode_scheme, show_now_playing, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, album_order_ascending, album_order_by_year, default_home_view, default_home_artists, default_home_albums, default_home_songs, artist_grid_width, album_grid_layout, related_artists, recommended_artists, reluctant_artist_loading, only_album_artist_recommendations, various_artists_shortlist, view_stats_for_all_users from user_settings where username=?]
Java version: Oracle Corporation 1.7.0_25
Operating system: Windows XP 5.1
Server: jetty/8.y.z-SNAPSHOT
Memory Used 26 of 29 MB
Stack trace:
org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select username, locale, theme_id, last_fm_enabled, last_fm_username, transcode_scheme, show_now_playing, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, album_order_ascending, album_order_by_year, default_home_view, default_home_artists, default_home_albums, default_home_songs, artist_grid_width, album_grid_layout, related_artists, recommended_artists, reluctant_artist_loading, only_album_artist_recommendations, various_artists_shortlist, view_stats_for_all_users from user_settings where username=?]; nested exception is java.sql.SQLException: Column not found: ALBUM_ORDER_ASCENDING in statement [select username, locale, theme_id, last_fm_enabled, last_fm_username, transcode_scheme, show_now_playing, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, album_order_ascending, album_order_by_year, default_home_view, default_home_artists, default_home_albums, default_home_songs, artist_grid_width, album_grid_layout, related_artists, recommended_artists, reluctant_artist_loading, only_album_artist_recommendations, various_artists_shortlist, view_stats_for_all_users from user_settings where username=?]
at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:233)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:603)
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:637)
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:666)
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:674)
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:714)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:58)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:62)
at net.sourceforge.subsonic.dao.UserDao.getUserSettings(UserDao.java:165)
at net.sourceforge.subsonic.service.SettingsService.getUserSettings(SettingsService.java:1021)
at net.sourceforge.subsonic.service.SettingsService.setDefaultMusicCabinetUserSettings(SettingsService.java:1091)
at net.sourceforge.subsonic.controller.MultiController.index(MultiController.java:93)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:471)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:408)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:827)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:648)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1336)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:101)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:54)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1307)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:453)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:559)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1072)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:382)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1006)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:365)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:485)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:926)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:988)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:635)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:627)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:51)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Unknown Source)
Caused by: java.sql.SQLException: Column not found: ALBUM_ORDER_ASCENDING in statement [select username, locale, theme_id, last_fm_enabled, last_fm_username, transcode_scheme, show_now_playing, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, album_order_ascending, album_order_by_year, default_home_view, default_home_artists, default_home_albums, default_home_songs, artist_grid_width, album_grid_layout, related_artists, recommended_artists, reluctant_artist_loading, only_album_artist_recommendations, various_artists_shortlist, view_stats_for_all_users from user_settings where username=?]
at org.hsqldb.jdbc.jdbcPreparedStatement.(Unknown Source)
at org.hsqldb.jdbc.jdbcConnection.prepareStatement(Unknown Source)
at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1436)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:581)
... 82 more
Regards, SoniXnSubs
SoniXnSubs
Re: Can't logon to MusicCabine v0.7. Why not?
Postby SoniXnSubs » Thu Jun 27, 2013 6:58 pm
Now my SubSonic installation is sort of ruined. How can I fix it - If I assume no one can give me the solution to my real problem :- )
ANyone?
Regards, SoniXnSubs
SoniXnSubs
Postby SoniXnSubs » Wed Jul 03, 2013 8:40 am
By installing several times I managed to get it to work. I also skipped the beta (?) version of postgresql I was using.
I did: 1) install musiccabinet 2) intall postgresql
Worx :- ) me happy!
Regards, SoniXnSubs
SoniXnSubs
Postby Rolphie » Tue Sep 30, 2014 12:51 pm
SoniXnSubs wrote:By taking advantage of Proextender and installing several times I managed to get it to work. I also skipped the beta (?) version of postgresql I was using.
Worx :- ) me happy!
I did the same and I still can't logon. Can't think of what else to do.
Rolphie
