Configuring Roku \w Subsonic Channel
Postby hamulu » Mon Jul 01, 2013 8:16 pm
I got the app Subsonic Channel. It asks for the server name and as an example gives 'server:4040'. I tried
myserver:8080
http://myserver:8080
http://192.168.1.100:8080
http://mysub.subsonic.org
However, I always get the error message that the connection to the server failed. The port is correct and so is the username and password. I can connect from other computers on the same network. The device is Roku 2 XS. Any advice on how to get this working is appreciated.
hamulu
Re: Configuring Roku \w Subsonic Channel
Postby reddwarf » Tue Sep 10, 2013 1:04 am
I had the same issue. My subsonic.org address and network IP do not work, I can only access my server by using my actual IP address with the port. Try http://www.whatismyip.com/ and see if that helps.
-RedDwarf
reddwarf
