Subsonic Android app cannot connect to the server
Postby HighCast » Thu Oct 01, 2015 9:43 am
After upgrading my subsonic to the 5.3 Beta 2 version, the Android mobile app(s) cannot connect to the server by using the same http://*.subsonic.org redirect that used to work earlier.
The normal server Web UI works as it should.
This has been tested with the local WLAN and also with mobile data connection - no luck.
Server tech info:
License Subsonic Premium
Version 5.3.beta2 (build 4547) – August 17 2015
Server jetty-6.1.x, java 1.8.0_60, Windows 10 (103,4 MB / 240,2 MB)
Mobile phone:
Sony Xperia Z3 Compact
Android 5.1.1
Subsonic App version 4.4, and tested also with Ultrasonic app - didn't work either.
Hoping this will get fixed to the official 5.3 release.
//Highcast
HighCast
Re: Subsonic Android app cannot connect to the server
Postby grumpwagon » Tue Oct 06, 2015 1:58 am
Did your subsonic port change when you upgraded? I use a *.subsonic.org redirect and it works fine.
grumpwagon
Postby HighCast » Tue Oct 06, 2015 6:01 am
grumpwagon wrote:Did your subsonic port change when you upgraded? I use a *.subsonic.org redirect and it works fine.
No, all is just as before. I just simply added an update. And as said, with web browser I can access it at same time but not with Android mobile application with "test connection".
HighCast
