DSub Bookmarks
DSub Bookmarks
Postby SeanyUK » Sat Apr 30, 2016 11:09 pm
When selecting a booked marked track DSub starts at the beginning, is this normal? Listen to lots of audiobooks sometimes the tracks can be hours long would be great if the app started at the bookmarked position, looked in the app settings for a way to active this but cant find any specific settings.
Any help would be appreciated.
Sean
SeanyUK
Re: DSub Bookmarks
Postby daneren2005 » Sun May 01, 2016 1:25 am
Can you look and see if it is cached before you click the bookmark? I just noticed that a bookmark I had the bookmark showed as not downloaded but the original listing showed it as cached. I need to look into why but was for a podcast in my case so I might be a different issue.
Re: DSub Bookmarks
Postby SeanyUK » Sun May 01, 2016 7:24 pm
Thanks for the reply. Yes the tracks are cached and have the blue PIN symbol.
SeanyUK
Re: DSub Bookmarks
Postby SeanyUK » Fri May 06, 2016 8:50 pm
daneren2005 wrote:Can you look and see if it is cached before you click the bookmark? I just noticed that a bookmark I had the bookmark showed as not downloaded but the original listing showed it as cached. I need to look into why but was for a podcast in my case so I might be a different issue.
Did you get chance to look at this?
SeanyUK
Users browsing this forum: No registered users and 42 guests
