New window when you upload music mod.
Postby cyclopes » Sun Apr 19, 2009 2:20 am
cyclopes
Postby jonathanroz » Wed Jun 10, 2009 8:28 pm
Cyclopes,
Thanks for putting this mod together. I found a few things that can be updated.
1) Your image names dont match the instructions on what to put in the default theme file.
loadImage_mini = icons/updisk_mini.png
should be
loadImage_mini = icons/up.png
2) Rename upwin.jsp to headup.jsp
3) It might make sense to remove the other upload option that is still listed under "More" to do that just open more.jsp and delete the following lines
<c:if test="${model.user.uploadRole}">
    <h2><img src="<spring:theme code="uploadImage"/>" alt=""/>&nbsp;<fmt:message key="more.upload.title"/></h2>
    <form method="post" enctype="multipart/form-data" action="upload.view">
        <table>
            <tr>
                <td><fmt:message key="more.upload.source"/></td>
                <td colspan="2"><input type="file" id="file" name="file" size="40"/></td>
            </tr>
            <tr>
                <td><fmt:message key="more.upload.target"/></td>
                <td><input type="text" id="dir" name="dir" size="37" value="${model.uploadDirectory}"/></td>
                <td><input type="submit" value="<fmt:message key="more.upload.ok"/>"/></td>
            </tr>
            <tr>
                <td colspan="2">
                    <input type="checkbox" checked name="unzip" id="unzip" class="checkbox"/>
                    <label for="unzip"><fmt:message key="more.upload.unzip"/></label>
                </td>
            </tr>
        </table>
    </form>
    <p class="detail" id="progressText"/>
    <div id="progressBar">
        <div id="progressBarContent"/>
    </div>
</c:if>
4) The formatting at the top is a little ugly for the new icon. If you update the code that you are adding to top.jsp to what I have below it looks cleaner
            <td style="width:4em;padding-right:1.5em"> <A HREF="javascript:newwindow()" ><img src="<spring:theme code="loadImage_mini"/>" title="Upload" alt="${more}"><br>Upload</a></td>
</c:if>
jonathanroz
Postby cyclopes » Thu Jun 11, 2009 9:50 am
Thanks.
8) [/b]
Vote Confirmation ;)
cyclopes
Postby jonathanroz » Mon Jun 15, 2009 4:49 pm
I noticed one other thing if you want to remove the upload function from the "more" so it is not in 2 places.
You need to remove the following code from the top of the more.jsp file as well or it will give you an error when you open it.
   <script type="text/javascript">
        function refreshProgress() {
            transferService.getUploadInfo(updateProgress);
        function updateProgress(uploadInfo) {
            var progressBar = document.getElementById("progressBar");
            var progressBarContent = document.getElementById("progressBarContent");
            var progressText = document.getElementById("progressText");
            if (uploadInfo.bytesTotal > 0) {
                var percent = Math.ceil((uploadInfo.bytesUploaded / uploadInfo.bytesTotal) * 100);
                var width = parseInt(percent * 3.5) + 'px';
                progressBarContent.style.width = width;
                progressText.innerHTML = percent + "<fmt:message key="more.upload.progress"/>";
                progressBar.style.display = "block";
                progressText.style.display = "block";
                window.setTimeout("refreshProgress()", 1000);
            } else {
                progressBar.style.display = "none";
                progressText.style.display = "none";
                window.setTimeout("refreshProgress()", 5000);
    </script>
jonathanroz
Users browsing this forum: No registered users and 35 guests
