play:sub not connecting
Postby cinchel » Wed Nov 21, 2018 5:03 pm
I can setup play:sub to connect to my subsonic server when i'm connected to my local wifi that the subsonic server is also on. but if i disconnect and try to connect from the outside i am not able to. i am able to connect to my subsonic server from the outside using iSub or just through the web address. is there a setting i am missing on the app or the server or my router ?
port forwarding is all set and works as evidenced by the other app being able to connect
thanks for any help in advance
jason
cinchel
Re: play:sub not connecting
Postby Michael Bech Hansen » Wed Nov 21, 2018 5:36 pm
play:Sub developer here...
If it works from iSub and web interface, it should also work from play:Sub.
If you DM me the server URL, I'll try to connect and see if there is something tripping up the app.
(alternatively, send a feedback email from within the app with the server URL).
Michael
Developer of play:Sub for iOS.
https://geo.itunes.apple.com/us/app/play-sub-subsonic-music-streamer/id955329386?mt=8
Michael Bech Hansen
Postby cinchel » Thu Nov 22, 2018 7:10 pm
ah! didnt think to use the contact form. filled it out. thank you for your help
cinchel
cinchel
Postby cinchel » Fri Nov 23, 2018 5:58 am
update: it was my own dumb fault. somehow my phone had turned off cellular data for the play:sub app.
thank you michael for reaching out.
cinchel
Postby timlance » Sat Nov 24, 2018 10:41 pm
HA ha. As I just wrote in another thread, Michael is one of the most responsive developers there is.
timlance
