Changing Tray Icon
Changing Tray Icon
Postby PieterB » Sun Jul 18, 2010 10:24 pm
I love Subsonic, I love the GUI, I don't like the subs. I already changed the favicon and I changed in C:\subsonic\jetty\webapp\icons the files subsonic_black.png and subsonic_white.png to something else.
That worked out.
In order to change the tray icon I changed the icons of C:\Program Files\Subsonic\subsonic-agent.exe and C:\Program Files\Subsonic\subsonic-service.exe
That did NOT work out.
Everything still works fine, but the tray icon is still the little clumsy sub.
Does anybody know how to sink the sub?
Thanks a lot for answering.
P.
PieterB
Postby mgrant » Mon Jul 19, 2010 9:27 pm
From what I can tell the subsonic-agent.exe icon is hard-coded to subsonic-16.ico. The only way I can see to change it would be to rebuild from source with a different icon.
However, you do not need to run subsonic-agent.exe for subsonic to work. It's the subsonic-service that does all the work. If you don't like the tray icon then just close it. Sub sunk.
-mg
mgrant
Postby PieterB » Mon Jul 19, 2010 11:24 pm
mgrant wrote:the subsonic-agent.exe icon is hard-coded to subsonic-16.ico. The only way I can see to change it would be to rebuild from source with a different icon
I changed the hard-coded icon with icoFX. Checking the .exe with another wonderful app XN Resource Editor a colorful home made icon is shown. So it seems as if the icon should be displayed. But it isn't.
Question is: where is that sub hiding.... Well that's what they're supposed to do, don't they?
I am starting to like that clumsy sub.
P.
PieterB
