Music folder accordion
Postby donpearson » Sun Feb 27, 2011 12:10 am
disgustipated wrote:funny, i just got it to work by choosing the 2 minutes to midnight theme
Now change it back to any theme and see it is still works, subsonic makes a cache of the theme you are using, so to see changes you make you need to change the theme or restart subsonic.
Facebook Group:
donpearson
Postby disgustipated » Sun Feb 27, 2011 12:23 am
Yeah, its fine now, it was cached
disgustipated
Postby mystery666 » Sat Apr 02, 2011 10:23 pm
Thanks everyone for your work on this. its not working for me. I'm running 4.4 build 2172.
I downloaded the zip, dropped the folders into the webapp folder. when it prompted me to overwrite existing files I said yes. I stopped and started the server, changed themes, still no change.
Is it necessary to remove those 3 existing folders before putting these in the webapp folder?
mystery666
Postby mystery666 » Sun Apr 03, 2011 2:49 am
Once I cleared my jetty cache, it worked. Now, please tell me what this theme 'ui-darkness' is and where do i get it?
mystery666
Postby westhaking » Mon Apr 04, 2011 5:31 am
mystery666 wrote:Once I cleared my jetty cache, it worked. Now, please tell me what this theme 'ui-darkness' is and where do i get it?
where is the jetty cache located?
westhaking
Postby kermit22 » Fri Apr 08, 2011 9:10 pm
westhaking wrote:where is the jetty cache located?
Stop the subsonic server and delete everything from this directory:
C:\subsonic\jetty\####\jsp\org\apache\jsp
kermit22
Postby kermit22 » Fri Apr 08, 2011 9:13 pm
thezoggy wrote:http://www.speedyshare.com/files/25884442/subsonic-accordion.zip
Here are all the files, just extract to the folder just before webapp.
So for example for me it was: C:\subsonic\jetty\1946\
Let me know if you have any problems.
--z
I love the mod thezoggy, but I was wondering how to change the colors. The blue and orange look terrible with the theme I'm using.
kermit22
Postby Minime » Sat Apr 16, 2011 12:24 pm
I will definitely give this mod a try. I like the idea and the look of it. Well done guys.
Best Regards
Minime,
Subsonic 4.6 | Ubuntu 10.04 LTS inside a VMWare host
Galaxy SII with ICS 4.0.1 & Android App v3.0 Combo
XBMC Dharma with t0mm0-xbmc-addons
+ A few custom Mods
Minime
Postby flandroid » Sat Apr 16, 2011 7:43 pm
I installed the mod in the OP, but now I find in the home displays (random, recently added, recently played, &c), there's an extra space between the artist and the album. Anyone know what I need to change in the CSS to get rid of this?
Edit: Looks like changing the line-height under .detail helped. Don't know why it didn't show up with the stock default.css, I think the values were the same...
flandroid
Postby deejay2302 » Thu May 05, 2011 5:01 pm
I have installed the zip Archiv and have accordion activated. I Use Slick Design. When i change design settings (color etc.) then he does not change colors.
And the buttons are a bit too wide. I would like to have Schmall. Only I do not find the settings for it. I have already reduced the graphics. Only, nothing changes. :(
I cleared browser cache and subsonic cache. Nothing!
My Layout Settings are (standart).
I will change the green and orange background-color and the horizantal-size of left side pictures to smaller size.
Example Picture:
My Settings on Slick.css
* CSS styleshet for the "Slick" theme.
* Author: Jeebs (Fisher Evans)
@import "default.css";
table {
color: #0e0e0e;
/* The primary background color. */
.bgcolor1 {
background-color: #0e0e0e;
/* The secondary background color. */
.bgcolor2, .ruleTableHeader, .log {
/* Put stuff here if you need to customize any of the frames. */
.mainframe {
.topframe {
.leftframe {
.rightframe {
.playlistframe {
/* Background color for selected header. */
.headerSelected {
background-color: lightyellow;
/* Background color for form controls (use default). */
input, select {
/* Hover color for form controls (use default). */
input:hover, select:hover {
/* The primary foreground color (black). */
body {
color: black;
/* The secondary foreground color used for h1, details etc (gray). */
h1, .detail, .albumComment {
color: #272727;
/* Foreground color used for h2, bold and tr. */
h2, b, tr {
color: #333333;
/* Link color */
a:link, a:active, a:visited, a:link *, a:active *, a:visited * {
color: #006699
/* Link hover color */
a:hover, a:hover * {
text-decoration: underline;
color: #DD6900
/* Color for warning messages. */
.warning {
color: red;
/* Simple dark border. */
.border1, .ruleTableHeader, .ruleTableCell, .headerSelected, .log {
border: 1px solid black;
/* Scrollbar colors (supported on IE and Opera) */
body {
scrollbar-face-color: #272727;
scrollbar-highlight-color: #FFFFFF;
scrollbar-shadow-color: #272727;
scrollbar-3dlight-color: #272727;
scrollbar-arrow-color: #006699;
scrollbar-track-color: #EFEFEF;
scrollbar-darkshadow-color: #272727;
/* Font 1 */
body, h2, form, label, table, a {
font-family: verdana, arial, sans-serif;
/* Font 2 */
h1, h1 a, .logo {
font-family: arial, sans-serif;
What am I doing wrong?
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby jared68 » Sat Jun 04, 2011 2:52 pm
Greetings I am a latecomer to this thread. I have the first instance working great, thank you for this.
But the archives seem to have died for the jquery accordion, could anyone point me towards where these might be?
Thank You!
jared68
Postby matzmann » Sun Jun 26, 2011 12:04 pm
Yes, please post a new location of the ZIP file.
Matthias
matzmann
Postby disgustipated » Sat Jul 02, 2011 5:52 pm
also looking for this .zip, i searched my computers and cant find it and lost which files were modified after updating to 4.5 beta.
anyone still have it?
to clarify im looking for the zip from thezoggy
disgustipated
Postby Qbix » Mon Jul 04, 2011 3:47 pm
thezoggy just send me a pm with a working link so:
http://www.speedyshare.com/files/292763 ... ordion.zip
Cheers,
14.985 artiesten
10.798 albums
90.526 nummers
822,06 GB (~ 12.770 uur)
Qbix
Postby disgustipated » Mon Jul 04, 2011 5:10 pm
Fantastic, I'll post it on my server as well so the link doesn't expire
disgustipated
