Subair not able to play M4a but can play mp3
Postby knemonic » Tue Oct 26, 2010 7:09 pm
Hello all,
I've been racking my brain trying to get this to work. Using latest version of subsonic, subair, adobe air and flash.
I am able to play mp3 files in subair, but when I attempt to play m4as, the total time and song/album info pop up, sit there for a bit, with no time elapsing on the clock and after about 6 or 7 seconds, the song goes away and I am not able to play any music after, mp3 or otherwise.
The od thing is I am able to download the m4a as an mp3 version, which plays fine.
I uninstalled Air and subair, reinstalled, still no dice. I enabled m4a to mp3 and aac to mp3 and also enabled them in the player section and it still does not work.
I also went as far as to install xcode and macport on my main system which hosts subsonic. That didn't seem to help either.
Any suggestions?
Thank you!
knemonic
Postby ggibby » Thu Nov 04, 2010 4:17 pm
*bump*
Find power in peace,
-G
x64W7 Ult
Intel i3-2100 3.1GHz - 8GB RAM
120GB Corsair SSD system
2TB WD Caviar HDD storage
2TB SmartStor NS4300N NAS
Gig Ethernet - SOHO cable internet
14,936 artists
6,196 albums
77,900 songs
634.03 GB
ggibby
Postby pha9992001 » Mon Apr 18, 2011 4:56 pm
this is a dated thread, but just in case anyone else runs into this issue...
I ran into this same issue with aacs, and did the following:
the transcoding settings need to be checked in two places...
1. subsonic > settings > transcoding
- enable 'aac > mp3'
- transcoding settings for aac > mp3 are as follows
step 1 > ffmpeg -i %s -v 0 -f wav -
step 2 > lame -b %b --tt %t --ta %a --tl %l -S --resample 44.1 - -
2. subsonic > settings > player
- select your player (subAir[username])
- scroll down to 'Active transcodings' and ensure that 'aac > mp3' is checked
I haven't tested with m4a, but it should work them as well.
pha9992001
Postby Skeletor » Tue Apr 19, 2011 8:58 pm
pha9992001 wrote:this is a dated thread, but just in case anyone else runs into this issue...
Thanks! It does work with m4a.
Skeletor
