Basic authentication in python?
Postby BestMuted » Thu Nov 11, 2010 4:32 pm
I am trying to use basic authentication with python, but I am still getting an error "Required parameter is missing." I am probably doing something wrong.
I am probably mis-reading this tutorial, but I am kinda lost http://www.voidspace.org.uk/python/arti ... ion.shtmlc
Here's the code I am using
def login(username, password):
    import urllib2
    superURL = 'http://localhost:8090/rest/'
    username = 'aaa'
    password = 'bbb'
    passman = urllib2.HTTPPasswordMgrWithDefaultRealm()
    passman.add_password(None, superURL, username, password)
    authhandler = urllib2.HTTPBasicAuthHandler(passman)
    opener = urllib2.build_opener(authhandler)
    urllib2.install_opener(opener)
    pagehandle = urllib2.urlopen("http://localhost:8090/rest/getIndexes.view?v=1.3.0&c=myapp")
    print parse(pagehandle).toxml()
BestMuted
Postby tags07 » Sat Mar 19, 2011 4:29 pm
How do you use basic authentication?
always comes back with:
<subsonic-response xmlns="http://subsonic.org/restapi" status="failed" version="1.4.0">
  <error code="10" message="Required parameter is missing."/>
</subsonic-response>
The only way to get it working is to pass user and password in the url. How does the basic authentication stuff work with python as an example?
tags07
Postby alexj212 » Sat Apr 16, 2011 3:21 pm
Here is how I create rest commands urls.
    def createUrl(self, method, args=[]):
        url = "http://%s/rest/%s?u=%s&p=%s&v=%s&c=%s&f=json" % (self.subsonic_server, method, self.user, self.password, self.api_version, self.app_name)
        for x in args:
            if x is not None:
                url= url+"&"+x
        print url
        return url
alexj212
Postby crustymonkey » Fri Apr 22, 2011 8:11 pm
I just put a basic Python library up on github to wrap the REST API yesterday. It takes care of all of this stuff for you:
https://github.com/crustymonkey/py-sonic
crustymonkey
