Place JW Player 5.4 SUBEQ Plugin above the player
Postby dba61 » Thu Jan 13, 2011 11:43 pm
Building on the great work of stozher http://forum.subsonic.org/forum/viewtop ... 9779#19779 the below modifications will put the SubEq plugin on top of the JW Player. Since the player will go from 24 px to 48 px high the padding must also be changed so the first track isn't hidden. For those of you who are color deficient like me this modification will help. I also set it to use a blue basecolor which allows us to see a seperation of colors. The items in Bold are the changes I made. The basecolors can be any HEX value http://htmlcolorcodes.org/ which are HTML safe colors.
The file we need to change is playlist.jsp. It can be opened with any Text editor. On a Linux system the easiest way is to open a Terminal session and type:
sudo gedit "/var/subsonic/jetty/XXXX/webapp/WEB-INF/jsp/playlist.jsp" replace xxxx with your version number.
1) Change the following from:
function createPlayer() {
var flashvars = {
backcolor:"<spring:theme code="backgroundColor"/>",
frontcolor:"<spring:theme code="textColor"/>",
plugins:"backstroke-1,subeq-1&subeq.gain=2&subeq.displaymode=decay&subeq.barbasecolor=00D61B",
var params = {
allowfullscreen:"true",
allowscriptaccess:"always"
var attributes = {
swfobject.embedSWF("<c:url value="/flash/jw-player-5.4.swf"/>", "placeholder", "340", "24", "9.0.115", "false", flashvars, params, attributes);
to this.
var flashvars = {
plugins:"backstroke-1,subeq-1&subeq.gain=2&subeq.displaymode=decay&subeq.barbasecolor=0000CC",
var params = {
var attributes = {
swfobject.embedSWF("<c:url value="/flash/jw-player-5.4.swf"/>", "placeholder", "340", "48", "9.0.115", false, flashvars, params, attributes);
2) Now we need to adjust the padding so that no tracks are hidden change this:
</script>
<div class="bgcolor2" style="position:fixed; top:0; width:100%;padding-top:0.5em">
<table style="white-space:nowrap;">
<tr style="white-space:nowrap;">
<c:if test="${model.user.settingsRole}">
<td><select name="player" onchange="location='playlist.view?player=' + options[selectedIndex].value;">
<c:forEach items="${model.players}" var="player">
<option ${player.id eq model.player.id ? "selected" : ""} value="${player.id}">${player.shortDescription}</option>
</c:forEach>
</select></td>
</c:if>
<c:if test="${model.player.web}">
<td style="width:340px; height:24px;padding-left:10px;padding-right:10px"><div id="placeholder">
<a href="http://www.adobe.com/go/getflashplayer" target="_blank"><fmt:message key="playlist.getflash"/></a>
</div></td>
</c:if>
<c:if test="${model.user.streamRole and not model.player.web}">
<td style="white-space:nowrap;" id="stop"><b><a href="javascript:noop()" onclick="onStop()"><fmt:message key="playlist.stop"/></a></b> | </td>
<td style="white-space:nowrap;" id="start"><b><a href="javascript:noop()" onclick="onStart()"><fmt:message key="playlist.start"/></a></b> | </td>
to this:
</script>
<div class="bgcolor2" style="position:fixed; top:0; width:100%;padding-top:-0.10em">
</c:forEach>
</select></td>
</c:if>
</div></td>
</c:if>
dba61
Re: Place JW Player 5.4 SUBEQ Plugin above the player
Postby trickydick » Tue Aug 30, 2011 2:12 pm
do you know how i can add this to a different part of the player? Like i currently have it inside the player which i'm ok with, but i want it moved to the right slightly so it doesn't cover the play/pause button. My current mod won;t support the above option, but it would be nice....if i were to hide/show the equilizer.
Tricky
trickydick
