change default view to "newest"
Re:
Postby appsfinder » Fri Mar 21, 2014 6:26 pm
benzubi wrote:hey
I try to use this but I can't find the line
<frame name="main" src="home.view?" marginwidth="0" marginheight="0">
in my index.jsp
weird :shock:
hi how do i do this in new version 4.9 (build 3819) hope you can help
appsfinder
Re: change default view to "newest"
Postby daneren2005 » Fri Mar 21, 2014 7:52 pm
Here is my change to do this on 4.9, but I did it directly in the code. I have no idea where these files are if you are editing the resulting folder.
https://github.com/daneren2005/Subsonic ... 9e17a4e7be
Postby ggibby » Fri Aug 07, 2015 3:33 pm
Understanding this post is really old,
seems like a lot of work for such a simple concept,
that has yet to be implemented by the devs (as far as I can tell).
-G
ggibby
Previous
